294 user(s) are online (245 user(s) are browsing Forums)
gascaleman dash speakers
South Georgia
20 Posts
I have 89 convertable with bad speakers in the top of the dash. I have not received my assembly and shop manual yet so I will ask you guys the dumb question. HOW THE HECK DO I GET THEM OUT? Thanks for your patience and help.
Posted on: 2009/6/27 23:14
bogus Re: dash speakers
There are a number of small phillips head screws along the leading edge of the dash board cover. Just under the overhang, IIRC.
Those need to come out. I think there are also a few at the leading edge inside the defrost vents.
From there, the pad should just pull straight back and come off.
Posted on: 2009/6/28 0:38
Matatk Re: dash speakers
This sucks, but like Andy said you'll have to take off the dashboard.
89 FSM instructions:
"Instrument Panel Upper Pad"
Remove or Disconnect:
1. Battery negative cable.
2. Steering column tilt lever.
3. Headlamp switch knob.
4. Eight instrument panel courtesy trim plate screws and courtesy trim plate.
5. Instrument panel trim plate (fuse).
6. Six screws from instrument panel upper pad.
7. Two screws from defrost duct.
8. Instrument panel upper pad.
Photobucket
Posted on: 2009/6/28 13:05
gascaleman Re: dash speakers
South Georgia
20 Posts
Forgot to ask what size speakers will it take to replace them. Thanks guys you have been a great help with my problems. I plan to replace those speakers next weekend. Again THANKS.
Posted on: 2009/6/28 22:33
Once you get it out, you can see them.
I don't remember off hand, but I htink they are 4" round... or very close to that.
Posted on: 2009/6/29 1:07
I've never removed them. From the dash picture it seems to indicate they might be oval, maybe 4x6?
Posted on: 2009/6/29 12:01
South Georgia
20 Posts
Speakers are 4 X 6 2 incehes deep. Dash pad is a little hard to get out and back in, you just have to wiggle and push and pull it. Watch for the small spring clip on the right side towards instrument panel, it can be a pain to get in place. Thanks guys for your help I now have sound in the car!!! I am looking for a CD changer that plays through the FM radio, is there such a thing , my xm radio does it, and which one do you suggest. I just don't want to do a bunch of wiring for it. My hearing is not so great and wife wears 2 hearing aids so fidelity is not as important as just hearing the music. Again THANKS your help has been great and appreciated.
Posted on: 2009/7/4 17:15
As far as the cd changer I used to have a clarion 6 disc changer I liked a lot that played through the fm channel. Just look for "fm modulator" when you search.
Posted on: 2009/7/4 17:35
