klkordzi | Head bolt question | ||
I'm in the middle of swapping the heads on my 85 and wanted to chase the threads for the head bolts but I'm having trouble finding a tap. I believe the bolts are 11m x 1.75. Does anyone know if this is correct?
Posted on: 2009/7/6 0:02
klkordzi | Re: Head bolt question | ||
Never mind. I assumed the bolt was metric but right after writing the post I did a little research on Summit and saw that all bolts for 76 to 2000 were the same. Went out to the garage and found they were just plain old 7/16 inch bolts.
Posted on: 2009/7/6 1:06
Durango_Boy | Re: Head bolt question | ||
Don't use a real tap. Use a specific chaser tool. They cut totally different and you don't want to compromise the integrity of those bolts. I would also suggest ARP moly bolts at the very least.
Posted on: 2009/7/6 3:08
BillH | Re: Head bolt question | ||
It's amazing how much you use a set of chasers after you buy them, especially on engines.
This one's from Craftsman. Attach file: IMGP0520.jpg (0.00 KB) |
Posted on: 2009/7/6 12:57
biggrizzly | Re: Head bolt question | ||
I bought the same set when I did my engine. Even though I only used a couple of the chasers they will definitley come in handy in the future and the set is not that expensive if I recall. |
Posted on: 2009/7/6 13:03
Yep, I run every threaded hole on a bare block with these before any assembly. IIRC, this set was on sale for $39, it has course/fine SAE and metric. |
Posted on: 2009/7/6 13:21
