203 user(s) are online (134 user(s) are browsing Forums)
Flashman Question for Joe Anesthes
Tampa Bay, Florida
174 Posts
Hi Joe,
I saw in your transmission swap write ups that you swapped a 700r4 corvette to a manual. What year corvette was that and did you have any problems mounting the clutch pedal bracket to the aluminum cross beam and the firewall? What year corvette clutch pedal did you use? Thanks.
Joe Flash
Posted on: 2009/7/7 19:58
Flashman Re: Question for Joe Anesthes
Tampa Bay, Florida
174 Posts
Hi Joe,
Never mind, I finally figured it out.
Joe Flash
Posted on: 2009/7/7 23:23
anesthes Re: Question for Joe Anesthes
Boston, MA
Flashman wrote:
Hi Joe,
Joe Flash
My guess is you figured out you needed to add some of those clip-on nuts for the 6mm or whatever size it was screws ?
Glad the swap is going well.
-- Joe
Posted on: 2009/7/9 2:33
Tampa Bay, Florida
174 Posts
Hi Joe,
No. The corvette junkyard that sent me the clutch and brake pedals sent me 90-96 clutch/brake assemblies. When I spoke to him thru email he knew that I needed 84-89. But his guys sent me the wrong assemblies. I couldn't believe it was the wrong parts. Its going pretty good if I can get the right parts to do the job.
Joe Flash
Posted on: 2009/7/9 3:42
