171 user(s) are online (122 user(s) are browsing Forums)
Stl94LT1 Tunercat Def File Problem
128 Posts
I just had Tunercat send me an updated version of their $EE definition file, and for some reason I can't find the fans on/off for coolant temperature in the ECM Constants tables. Any idea what I'm overlooking?
Posted on: 2008/1/1 19:07
vis_croceus Re: Tunercat Def File Problem
VA
260 Posts
I seem to recall reading that it moved to its own table a while back.
Still using an older version here so I can't confirm.
Posted on: 2008/1/1 20:18
Stl94LT1 RE:Tunercat Def File Problem
128 Posts
OK, I found it. You're right, it now has it's own table.
"Fan Enable Coolant Temp vs Speed"
Posted on: 2008/1/2 2:58
rickreeves1 RE:Tunercat Def File Problem
New Orleans
96 Posts
Whats different? Why the update? I'm still using the older def file also.
Posted on: 2008/1/2 3:19
128 Posts
Rick, I'm not sure of all the changes. The main one I wanted was a constant table that would allow me to correct my trip computer's mpg once I change injectors.
"Display injector flow rate"
Tunercat will send you the update, and it only takes a few minutes to install.
-Mike
Posted on: 2008/1/2 3:32
vis_croceus RE:Tunercat Def File Problem
VA
260 Posts
People are always figuring out new bits to twiddle. Mostly esoteric stuff these days.
That's been in there since the beginning of time. But I'm EEb, so maybe it's only been in EEb not EE? Or you were using a _real_ old version?
Posted on: 2008/1/2 7:52
128 Posts
vis', my original version was ~6 years old.
Posted on: 2008/1/2 17:35
VA
260 Posts
Damn. You should find all kinds of new things to play with in that case.
Posted on: 2008/1/2 22:26
