Midnight85 | Paging Pete K, squeak, part 2 | ||
Hi Pete,
I was finally able to get the time to get the trans out of the car, there is nothing wrong with the front pump including the rotor. The only thing I found wrong was the small cone shaped mesh filter that goes into the side of the pump was not snapped it place. It wouldn't snap into place so I replaced it with another one I had. No shavings anywhere in the pan or otherwise. Can it be the torque converter? Externally the converter looks perfect so where do I go from here? |
Posted on: 2009/8/18 2:00
HORSEPOWER! Some is good, more is better, too much is just right. |
PeteK | Re: Paging Pete K, squeak, part 2 | ||
I have never (yet) seen a torque converter squeek.
Take the converter to a local trans shop and ask them to measure the end play. If it is excessive, swap it out. |
Posted on: 2009/8/18 2:07
