209 user(s) are online (154 user(s) are browsing Forums)
Also known as the DIC.
tjwong Modified injector question.
7 Posts
When FIC modifys the Bosch EV14 injectors to their 70#, 83# and even a 100# (1000cc) ratings. How is that done, and how is the low end performance of these injectors vs a factory produced injector of the same rating. The reason I ask is because I have installed some of thes modded injectors that cam with a blower kit into a LS3 C6 and found that they were dirty down in the lower operating RPMs. I don't know where they came from as far as the source goes as the package was just a ziploc baggie. I have a need for the larger 850cc EV14s but I want to be sure I am not going run into the same tuning issues with using your injectors.
In the applicatio I mentioned I ended up using a adapter to run a set of peak and hold injectors which worked out great, no more issues with tuning. I just don't want to have to do that again as wiring it was a PITA and not to mention I have to explain to a customer that he needs to spend more money is also a PITA.
Posted on: 2009/8/17 4:56
Matatk Re: Modified injector question.
I'm sure Jon will chime in soon, but I can guarantee you the injectors I got were not in a ziplock baggie....lol. When I received my injectors they were clean and looked brand new, and were in a heat sealed bag, very professional.
Jon will take care of you, TJ.
Posted on: 2009/8/17 14:33
FICINJECTORS Re: Modified injector question.
Gold Sponsor Vendor
117 Posts
hey TJ. I know there are about 15 companies that mod these injectors. We sell them wholesale in bulk then they are repackaged with the kits. However, we have had a jig made that holds each injector at the proper angle prior to machining. We have sold over 500 sets of the modded version from 55 to 91lb with no problems.. Bosch only makes the ev14 to 52lbs, so the market is very big for these.. We make them for the LS series, Porsche, Subaru WRX, Audi and Ford GT500. Call me to discuss. If I sell you a set and you are not happy with them I will give you 100% money back.. Are you tuning these with the multiplier table or the VE.. 770 888 1662
Posted on: 2009/8/18 16:12
