292 user(s) are online (233 user(s) are browsing Forums)
1987c4red slight hesitation at 61mph and above is speed is held steady
SW Florida
40 Posts
When speed is held steady at or above 61 mph I get a slight hesitation. If I accelerate it doesnt happen.
Posted on: 2007/11/13 21:57
CSS996 RE:slight hesitation at 61mph and above is speed is held steady
Mega Guru
Central PA
3644 Posts
Welcome to the forum!
Hopefully somebody can chime in with the answer here shortly. How old are the plugs and wires?
Injectors?
Posted on: 2007/11/13 22:16
Currently "Between Vettes".
bogus RE:slight hesitation at 61mph and above is speed is held steady
Welcome aboard! We will need more info... for us to help you, you need to help us.
mileage? overall maintenance history?
Posted on: 2007/11/14 5:11
JrRifleCoach RE:slight hesitation at 61mph and above is speed is held steady
1524 Posts
Seems like a slight vacuum leak might be the problem.
Using a short piece of tubing or garden hose, listen for leaks while the engine is idling.
Also try checking the intake tubes and plenum bolts for tightness.
Good luck
Posted on: 2007/11/14 8:33
toptechx6 RE:slight hesitation at 61mph and above is speed is held steady
south Florida
362 Posts
Sounds like you may be describing lock up cycling of the torque converter or an engine miss, but as others indicate your description isn't very clear.
The term hesitation normally describes lack of response to throttle movement on acceleration which confuses the issue for me.
Posted on: 2007/11/14 9:05
1987c4red RE:slight hesitation at 61mph and above is speed is held steady
SW Florida
40 Posts
Thanks for the responses and I will try to give more information. New plugs, wires, cap and rotor. 55K miles. injectors are orginal. Car sat in a garage for last nine years with only approx. 9500 miles driven. Added a bottle of injector cleaner. intend to add another next fill-up.
It was suggested that I check for vacuum leak. where specifically? hesitation happens at 61 and speeds above held steady. Can also experience issue when car is stopped and in nuetral reving engine to high rpm and again held steady.
Posted on: 2007/11/14 13:43
CasetheCorvetteman RE:slight hesitation at 61mph and above is speed is held steady
Sounds like a miss-fire to me, after sitting 9 years there could be alot of things to cause that.
Clean the MAF sensor, check the coil, check the oxygen sensor, check the EGR function to be sure its fully closed when it should be, replace the fuel filter, change the oil and filter, fill the tank with good quality fuel, take it to the race track and flog the tits off it for about 150-200 miles. That should clear its throat.
Posted on: 2007/11/14 13:56
south Florida
362 Posts
Easy mate, flogging their bloody tits off will get you arrested for domestic violence on this side of the big pond!
Posted on: 2007/11/14 14:36
daddue11 RE:slight hesitation at 61mph and above is speed is held steady
Mountain View, Southern Mo.,
131 Posts
That only applies to the Fleshy Kind. The fiberglass version is fair game.
Posted on: 2007/11/14 16:29
Aint no amount of gold in any ole mine,that would be enough to take away this car of mine.-beach boys
Posted on: 2007/11/14 16:35
SW Florida
40 Posts
let me ask a newbie questions. How do you clean a MAF sensor?
Posted on: 2007/11/19 14:49
SW Florida
40 Posts
Case,
Being a newbie how do you Clean the MAF sensor?
Posted on: 2007/11/19 14:50
With great care, use some mineral turps or methylated spirits, and clean it with a very soft paint brush. Use extreme care not to damage the wire.
Posted on: 2007/11/20 9:31
SW Florida
40 Posts
Case, thanks for the info. As you can tell I am not to knowlegable about fuel injection systems. I have building custom harley for years. Found 87 c4 in lady's garage She put less than 9K mile of it over 9 years. discovering whole new world of hot rods again.
PS Took your advise and "flogged the tits off" of it last weekend......boy have I got the fever!
Posted on: 2007/11/20 14:52
SW Florida
40 Posts
Case,
Can I use a typical aerosol cleaner typically use to clean trottle body for MAF?
Posted on: 2007/11/20 14:56
Yes mate you can use that, and that might even be a better option for it too, just use caution that the pressure isnt too high. If this MAF still has screens on it, remove them.
Did giving it a flogging help to clear it out abit? If not, ill bet you had fun doing it eh?
We may have to discuss custom Harleys abit further at some time, i have alot of mates with Harleys over here.
Posted on: 2007/11/21 3:31
SW Florida
40 Posts
Thanks Case,
Still have problem. Getting frustrating now. Somebody please give me the magic answer!
Posted on: 2007/11/21 13:21
I will have to refer to my 1987 Helm Manual...
Posted on: 2007/11/21 15:30
SW Florida
40 Posts
Any luck on the Helm manual, I'm still trying to find the problem?
Posted on: 2007/12/18 19:57
Cant you find it in your GM service manual?
Posted on: 2007/12/19 8:16
