178 user(s) are online (155 user(s) are browsing Forums)
Steve40th Split BLMS, Can you look at log and see anything?
1114 Posts
I will try to upload a TTS datalog for my 93. My BLMs are split pretty bad. WHat changed, just the injectors. I changed the constant, and that was it.
uni 42lbpart3.uni Size: 429.38 KB; Hits: 90
Posted on: 2010/7/21 3:22
Ko'u ohana aia ku'a ikaika
Aboatguy Re: Split BLMS, Can you look at log and see anything?
My Avatar was redistributed!
498 Posts
Steve,
I tried to play the file but for some reason it doesn't look right on my netbook.
Posted on: 2010/7/26 15:35
Steve40th Re: Split BLMS, Can you look at log and see anything?
1114 Posts
Aboatguy wrote:
Steve,
I think its because you need the actual TTS file for my DA2 build.
Posted on: 2010/7/26 15:41
vis_croceus Re: Split BLMS, Can you look at log and see anything?
VA
260 Posts
Save as CSV?
Posted on: 2010/7/26 22:30
94 vert
1114 Posts
vis_croceus wrote:
Save as CSV?
The TTS is a UNI file. CSV was related to DIACOM I think. Not sure.
Unless you know something I dont, can you change a uni to a file CSV?
Posted on: 2010/7/26 22:45
VA
260 Posts
Steve40th wrote:
vis_croceus wrote:
Save as CSV?
Datamaster exports to csv.
Posted on: 2010/7/27 4:55
94 vert
1114 Posts
vis_croceus wrote:
Steve40th wrote:
vis_croceus wrote:
Save as CSV?
How do I do it? I need to read up on this.
Here it is, pretty cool.
csv July232010csv.csv Size: 916.37 KB; Hits: 64
Posted on: 2010/7/27 4:59
