Touringmike | What's with the GURU clock? Is it GMT ?? | ||
Seems to be 2 hours ahead of me (I'm in the CST zone), on a military clock.
So, enlighten us time challenged types. |
Posted on: 2007/12/29 20:10
´85 4+3 |
Notorious | RE:What's with the GURU clock? Is it GMT ?? | ||
Click on your profile and you can edit it to your time zone.
Posted on: 2007/12/29 20:15
I hate sporks... |
Touringmike | RE:What's with the GURU clock? Is it GMT ?? | ||
Click on your profile and you can edit it to your time zone. DOH!!!!!! GMT minus 6 hours. |
Posted on: 2007/12/29 20:19
´85 4+3 |
RollaMo-LT4 | RE:What's with the GURU clock? Is it GMT ?? | ||
Trivia Winner
And if you don't like the 24 hour clock, in the forums date format field change the capital H to a lower case h. The add an A on the end to get the am or pm function added
example: h:i:s:A will display like 10:26:00 PM |
Posted on: 2007/12/30 4:28
[quote]And if you don't like the 24 hour clock, in the forums date format field change the capital H to a lower case h. The add an A on the end to get the am or pm function added
example: h:i] Thanks for the tip. That was going to be my next question. Now, I'll just wait until noon to pass. :thumbleft: |
Posted on: 2007/12/30 15:10
´85 4+3 |
rickreeves1 | RE:What's with the GURU clock? Is it GMT ?? | ||
This will take a little getting used to. How do I view subscribed threads and how do I set it to automaticaly subscribe to threads I post in? Is there a way to change word wrap length so I don't have to keep scrolling to the right. I'll go try to figure it out.
Thanks |
Posted on: 2007/12/30 15:18
95-Lt1-auto-Polo-Conv, 125hp ZEX N2O dry, LE Cam 226/234 565/565 109LSA, Comp Pro Mag 1.6rr, Patriot Xtreme Springs, PCMFORLESS, K&N, AO Ram Air, 52mm TB, EM LT Headers, X-pipe, Meziere HD EWP, Vigil 2800, TransGo Shift Kit, Pro-Built Trans, 24lb SVO'... |
dan0617 | RE:What's with the GURU clock? Is it GMT ?? | ||
I figured out the clock thing, cool! you can also delete the seconds so it just shows hours and minutes. As for the scrolling to the right, I lowered my character width or whatever it is called from 70 to 65 and the problem went away.
Posted on: 2007/12/30 19:54
brut | RE:What's with the GURU clock? Is it GMT ?? | ||
The scrolling to the right usually happens when someone posts a large picture. I will try to find the patch that automatically shrinks them
If you look to the bottom of the forum index page near "whos online" you will see an option called "view my posts"...click on it and then bookmark it. Later I am going to try to add a link to the top to make it easier. |
Posted on: 2007/12/30 20:11
Thanks for that tip, I've been looking for that.
Posted on: 2007/12/31 16:15
