254 user(s) are online (206 user(s) are browsing Forums)
iCorvette How do I remove the rubber ball joint boots?
302 Posts
I got some new front control arms and want to put poly ball joint boots on, I can't seem to figure out how the original ones are attached, don't want to rip it... or should I leave it.
the bushings on them are beautiful, I am very hesitant to slap polys on them, should I just install them as they are?
your comments appreciated....
Posted on: 2010/12/31 21:18
bogus Re: How do I remove the rubber ball joint boots?
are these arms NEW or just new to you?
Posted on: 2010/12/31 21:36
BrianCunningham Re: How do I remove the rubber ball joint boots?
Didn't they come with BJ's?
Is so, if they haven't dryrotted, I'd leave them.
iCorvette Re: How do I remove the rubber ball joint boots?
302 Posts
They are NOS arms from corvette recycling, they are supple as the day they were made....
should I leave the boots as well?
Posted on: 2010/12/31 21:43
No reason not to.
Stockers are what I'm running on my new setup.
<------- (see Avatar)
Posted on: 2010/12/31 22:03
302 Posts
hello
Posted on: 2010/12/31 22:07
302 Posts
BrianCunningham wrote:
No reason not to.
I thought the stuff i see on your avatar is a forgone
conclusion...
check this out....
http://www.eng-tips.com/viewthread.cfm?qid=287903&page=1
Posted on: 2010/12/31 22:08
