smooth | Fuel rail ? | ||
.....along with all of my other projects, I have a '96 block I'm gathering parts for. I have a guy that says he has the fuel rail setup, but its for a '93LT1. Nothing ever changed about them through the entire lt1 series of engines correct?
Thanks, alan |
Posted on: 2011/1/7 13:44
Alan 2001 Navy Blue Metallic Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. Dr.Seuss |
rklessdriver | Re: Fuel rail ? | ||
Incorrect.
92-93 had the crossover in the rear of the fuel rail. 94-96 have the crossover in the front of the fuel rail. You can use 92-93 rails on any year LTX intake manifold however 94-96 rails will not fit on 92-93 intake manifolds as they are cast solid behind the TB. Also be careful of which rails you buy because the Y body, F body and B Body all use different connectors and are located in different places for the fuel lines. Will |
Posted on: 2011/1/7 16:59
smooth | Re: Fuel rail ? | ||
Aha! Thanks Will. I can always count on you guys!
Posted on: 2011/1/8 2:11
