292 user(s) are online (253 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
KyVaderVette Fuse question
Louisville, KY
28 Posts
I'm thinking that some of these minor issues w/my '95 are (hopefully) fuse related. I have the chart in the owner's manual which gives me the appropriate diagrams, but what I haven't seen is, and I know this is probably a most newbie-like question, but how do I know what strength/power/volt/amp, etc.. of fuse to use for each of the required applications? I'm hoping this will help w/some of those "little" problems.
Posted on: 2011/5/14 20:10
1Fast04Vert Re: Fuse question
Look inside the fuse cover. Everything you should need to know is right there.
Posted on: 2011/5/14 20:19
KyVaderVette Re: Fuse question
Louisville, KY
28 Posts
Ah, yes....I looked at the charts in the manual, but never actually looked inside the fuse box itself....I told you it was a newbie-like question!!!
Posted on: 2011/5/14 20:21
No problem, owning a C4 leads to continuing education. I learn something new about my 95 almost every day.
Posted on: 2011/5/14 20:41
bogus Re: Fuse question
If you think one C4 is a learning curve, try 2...
There is also a fuse panel in the engine compartment behind the battery.
Posted on: 2011/5/14 21:07
