matts85vet | computer tune needed for 85 with new gear ratio | ||
3.75 gears are in!
my chip was done previously by jesse azzato any suggestions? |
Posted on: 2011/6/23 2:19
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x- |
bogus | Re: computer tune needed for 85 with new gear ratio | ||
PM mseven.
Posted on: 2011/6/23 7:00
Matatk | Re: computer tune needed for 85 with new gear ratio | ||
Did you only change the gear ratio? Then why do you need a tune?
Matthew |
Posted on: 2011/6/24 15:15
matts85vet | Re: computer tune needed for 85 with new gear ratio | ||
yes just the gear ratio
it runs pretty rich also. i was told that the tune may not be the best quality. |
Posted on: 2011/6/25 2:30
If you are trying to change the tune for the speedometer, it's controlled by plastic gears in the trans.
If you want to change the tune because you don't like the one in there, try Mick on here or PCM4less. Matthew |
Posted on: 2011/6/25 3:12
