istter1 | ABS over size tires 87 vett | ||
The tire size are 18" and 19" 20" wide with C6 rims. Found a little rubbind off the plastic on the drivers side rear. Another question was will it be driveable with 16" spare tire. It was lowered an 1" in the front
Posted on: 2011/7/11 16:14
1Fast04Vert | Re: ABS over size tires 87 vett | ||
Obviously the handling would be terrible, but you could also burn up the rear end.
Posted on: 2011/7/11 18:12
istter1 | Re: ABS over size tires 87 vett | ||
handles great only problem has been the ABS light staying on. And losing the hydrolics on the clutch. We while we were replacing the entire clutch system took it apart it looks great ... Knock on wood. Lol
Posted on: 2011/7/11 18:59
BrianCunningham | Re: ABS over size tires 87 vett | ||
what was wrong with the 1st thread?
http://www.corvette-guru.com/modules/ ... hp?topic_id=15296&forum=1 |
Posted on: 2011/7/11 20:53
I thought he was asking about running a 16" spare in this topic. At least that is what I responded to.
Posted on: 2011/7/11 20:55
Woops i miss understood. Been a long day
Posted on: 2011/7/11 22:44
