qwik6 | How do you align the waterpump shaft splines? | ||
I'm looking for anyone who can give me some advice on how to align the waterpump driveshaft splines so the pump will slide on smoothly. I thought I would just try and use the attachment bolts and force the pump on. I got scared that I would bend the aluminum housing on the pump so I backed out of that strategy. Its going on a '96 LT-4 and its a new delco pump. Any help would be greatly appreciated....
Posted on: 2011/11/11 20:42
1Fast04Vert | Re: How do you align the waterpump shaft splines? | ||
It should just slide right on, it is not keyed where you would have to line up the splines just right or anything.
You are right - don't use the bolts to force it on. |
Posted on: 2011/11/11 20:48
pianoguy | Re: How do you align the waterpump shaft splines? | ||
You could just turn the engine a smidgen using the crank bolt.
Posted on: 2011/11/11 21:11
tjpreul | Re: How do you align the waterpump shaft splines? | ||
There are two o-rings that could cause binding. Be sure the splines are clean in the coupler. The o-rings will be on the shaft out of the timing cover and on the waterpump. Be sure you have them greased, and the coupler will slide on. I believe the groove on the coupler goes towards the engine. As 95vette stated there isn't an alignment spline.
Posted on: 2011/11/11 21:14
The coupler has grooves that mate up with the drives on the cam and water pump. Last time I installed my water pump, I had to jog the engine a bit to get the pump to slide on freely. An alternative would be to use the coupler to turn the pump a little.
It's probably a random situation where the pump splines are hitting the coupler right between the grooves. When I first took my new pump out of the box, it slid right on. |
Posted on: 2011/11/11 22:26
