238 user(s) are online (184 user(s) are browsing Forums)
Ajetsprt 1992 Need help with broken piece in steering column
66 Posts
Hi,
I pulled my steering wheel tonight to replace it with a restored one and found that the sleeve (located on the steering column) that the contact wire for the horn goes to is broken. The sleeve has a channel in it that the horn wire pushes into and then the wire hooks in place under some pressure from a spring to keep electrical contact. Does any one have any idea where I can get this piece or the proper way to disassemble the column at this point?
I removed the C-Clip from the shaft and could feel there is some type of spring behind it so I put the clip back in place while I checked with the experts here..
jpg  photo3.JPG (132.85 KB)
2020_4f1a317c89c5d.jpg 650X867 px
jpg  photo.JPG (123.23 KB)
2020_4f1a3187e38b2.jpg 650X488 px
jpg  photo2.JPG (106.18 KB)
2020_4f1a31934d13b.jpg 650X867 px
jpg  photo4.JPG (106.58 KB)
2020_4f1a319b921cb.jpg 1014X732 px
Posted on: 2012/1/21 3:33
joeld Re: 1992 Need help with broken piece in steering column
Here's a some good pictures, should help.
http://domesticmisfits.net/forums/vie ... rvette+steering+clumn+fix
Posted on: 2012/1/21 4:02
These folks might have what you need.
http://www.steeringcolumnservices.com/index.php
Posted on: 2012/1/21 4:11
bogus Re: 1992 Need help with broken piece in steering column
I think you can just epoxy that back together. I don't remember there being much load there.
Posted on: 2012/1/21 4:37
josephf31 Re: 1992 Need help with broken piece in steering column
New Jersey
375 Posts
I think that's the same part that was broken on my '91 (there were so many it's hard to remember LOL) but I think I was able to get it from either Corvette Central or Eckler's
Posted on: 2012/1/21 5:06
vetteoz Re: 1992 Need help with broken piece in steering column
Turn signal cancel cam
http://www.ecklerscorvette.com/corvet ... elling-cam-1990-1996.html
#7 in diagram
http://i171.photobucket.com/albums/u3 ... eoz/electrical/Column.jpg
Posted on: 2012/1/21 6:08
New Jersey
375 Posts
#7 in diagram
Dem's the one! You can even get them at NAPA for about $7
Posted on: 2012/1/21 6:34
Ajetsprt Re: 1992 Need help with broken piece in steering column
66 Posts
Thanks everyone...
Bogus I took your advice and used some epoxy and then JB Weld on it and it's working and all back together again. Vetteoz got me the correct part info so I am ordering it to have incase it breaks in the future. The horn did not work from when I bought the car and now i know why..
I have the car up on stands so I can remove all four wheels and give it a good cleaning in the wheel well area. I hope to post some pictures as soon as I finish.
Thanks again...
Posted on: 2012/1/25 1:14
