pappyfreebird | rookie question | ||
does the air con.evaporater cover the entire front of radiator??
Posted on: 2008/1/8 15:40
biggrizzly | RE:rookie question | ||
Pretty Much, if not 100%
Posted on: 2008/1/8 16:14
CFI-EFI | Re: rookie question | ||
does the air con.evaporater cover the entire front of radiator?? The "air con.evaporater" (sic) is mounted on the firewall at the right rear of the engine. The radiator is at the front of the car, approximately between the headlights. There are several feet between the two. One, in no way covers the other. RACE ON!!! |
Posted on: 2008/1/8 16:40
EFI,
I was assuming he meant the condensor. I know we shouldn't assume what the poster wants. Cheers! |
Posted on: 2008/1/8 16:44
MK 82 | Re: rookie question | ||
does the air con.evaporater cover the entire front of radiator?? No, but the condenser does. |
96 CE Roadster LT4 |
pappyfreebird | RE:rookie question | ||
thank you guys...id changed from con to evap twice nawt knowin what the L im callin stuff ...but thanks for answering my question..thats what i thought...pappy
Posted on: 2008/1/8 20:16
