326 user(s) are online (270 user(s) are browsing Forums)
Matatk Alan's 2001 "Service Active Handling Soon" warning message.
22803 Posts
From daily chat, I feel it is worthy of its own tech thread:
On the Corvette side of things. The Message Service Active Handling Soon keeps coming up. I checked the codes and they were C1277H and C1288H. I cleared them and only the C1288H code returns after a short period (maybe a mile) of driving.
This message disappears if I shutdown and restart the car. I cleared the code again and tried a suggestion from THAT forum. Went to an empty parking lot and locked the steering wheel in both directions several dozen times. This seems to keep the code away for at least 10 miles of driving. If I cleaned and worked a sensor connection somewhere between the steering wheel and the wheels, Anybody know which one or ones and is there a possibility that they could be cleaned properly TO RID THE PROBLEM!
Thanks,
Alan
Posted on: 2012/6/22 2:01
Ultraman Re: Alan's 2001 "Service Active Handling Soon" warning message.
14738 Posts
Here is some info that I found. Have you had any work done to the steering column on your car? Sometimes they can put things back 180 degrees out. If not it may be the sensor is failing.
The c1288 is the code for the steering position sensor circuit. This sensor can fail but it needs to be checked first before replaced. I read somewhere that with the steering wheel straight the sensor should read 2.5 volts. The service manual for the 2001 should have the procedure for that.
If it needs to be replaced the steering column needs pulled which can get dicy with the air bag. The sensor is not that expensive but the labor to get it done can be pricey.
Here is a thread from that forum that has some info in it that pertains to the 1288 code. You may have seen it.
http://forums.corvetteforum.com/c5-te ... andling.html?ref=esp-link
Posted on: 2012/6/22 4:36
Matatk Re: Alan's 2001 "Service Active Handling Soon" warning message.
22803 Posts
Alan - 1277 is a code for "requested torque signal circuit malfunction. I'm assuming you meant 1287 which is "steering sensor rate malfunction." 1288 is "steering sensor circuit malfunction."
Check this link, too:
http://forums.corvetteforum.com/c5-te ... heel-position-sensor.html
Posted on: 2012/6/22 11:38
22803 Posts
Posted on: 2012/6/22 11:44
14738 Posts
Good links Matt...I know active handling can save you but its also one more thing to go wrong. If you turn the AH off and clear the codes will they not come back if the sensor in bad? I doubt it.....now that I think of it.
The Guru needs to continue to build its library of C5 fixes.
Posted on: 2012/6/22 13:27
smooth Re: Alan's 2001 "Service Active Handling Soon" warning message.
Formerly "Aquavet" in Pa.
386 Posts
Thanks for sticking this in Tech Matthew. You are correct...fat fingers....Original codes were 1287 and 1288.
The C1288H code does come back. I looked over the tech link that involved changing the sensor at the base of the steering column. I'm unable to play contortionist to get under the dash. I do belong to the Corvette club of Delaware Valley and we have a sponsoring dealer, Bryner Chevy, that gives A 10% break to club members. I may just end up taking it to them....I'm waiting for a call back from them as I type. Keep posting any info you locate though. It may help someone else!
Thanks Guys!
Alan
Posted on: 2012/6/22 16:13
Alan
2001 Navy Blue Metallic
j3studio Re: Alan's 2001 "Service Active Handling Soon" warning message.
Bryner Chevrolet has a long history of extensive Corvette club support. If you are giving any dealer your money, I could think of far worse.
Posted on: 2012/6/23 18:08
386 Posts
Bryner's expert, Steve Spencer, looked it over for me. He said it was missing a computer update that spreads the limits of the date the system uses to apply the Active Handling. The Reflash of the computer was all that was needed. All of the sensors checked out. With the Club Discount, it ended up being around $150. And now all is well.
Posted on: 2012/6/30 20:38
Alan
I'd take it ...
... thanks for the update!
Posted on: 2012/6/30 22:04
14738 Posts
Dats good news, thanks for keeping us posted on it.....
Posted on: 2012/6/30 23:23
