bren68 | lug nuts | ||
my next project is going to be brakes only thing is lock key for the 1985 is stripped any ideas I tried to chisel it off did not work also can not find a reverse thread socket that will fit over it any ideas would be great also if anyone knows where i can purchase the key i had no luck thanks
Posted on: 2012/10/22 3:04
bogus | Re: lug nuts | ||
You have a few options left...
Try drilling the thing off. If you can drill into the lug, then hit it with the chisel. Also, make sure you have the other 4 lugs in, this way, the one lug isn't holding all the load. Check in your area for someone who has a plasma drill. They usually can come to you. They are very common in the boating industry. These tools can melt a broken stud out of threads without hurting the threads. |
Posted on: 2012/10/22 4:15
Matatk | Re: lug nuts | ||
If you have locking lugnuts I would suggest trying a local tire place. They often have a wide range of keys and will charge you a few dollars to get it off.
You can also try to beat a slightly larger socket on it and try to get it off that way. As far as purchasing a key...good luck. Usually you just have to buy a new locking socket set. I am personally not a fan of them. Matthew |
Posted on: 2012/10/22 12:32
donhall | Re: lug nuts | ||
Posted on: 2012/10/22 15:11
Posted on: 2012/10/22 18:17
vis_croceus | Re: lug nuts | ||
Pretty much any tire place should have the tools to remove them if you haven't buggered them up too much.
Posted on: 2012/10/27 23:36
94 vert |
