103 user(s) are online (50 user(s) are browsing Forums)
BrianCunningham FBI arrests Chinese Contractor who worked for NASA
Why did NASA hire a Chinese national in the 1st place???
http://www.huffingtonpost.com/2013/03 ... n_2908082.html?1363719774
NORFOLK, Va. — A Chinese national who worked at NASA's Langley Research Center has been arrested on a plane bound for Beijing on charges of lying to federal agents.
Bo Jiang made his initial appearance Monday in Norfolk federal court. It wasn't immediately clear whether Jiang had an attorney.
U.S. Rep. Frank Wolf says Jiang wasn't employed by NASA, but worked at the Hampton, Va. facility for the National Institute of Aerospace.
An affidavit says Jiang was under investigation for possible violations of the Arms Control Export Act.
The affidavit says Jiang was arrested aboard a plane at Dulles International Airport on Saturday when he failed to disclose all of the electronics he was taking with him.
The affidavit says Jiang had previously taken a NASA laptop to China that contained sensitive information.
Posted on: 2013/3/19 21:12
rklessdriver Re: FBI arrests Chinese Contractor who worked for NASA
I would think they hired him because they knew he was an easy mark for an espionage arrest....
Posted on: 2013/3/20 1:59
Scott7 Re: FBI arrests Chinese Contractor who worked for NASA
Aurora, CO
169 Posts
Our government doing what they do best
Posted on: 2013/3/20 19:04
