sliding | Which head gasket | ||
I need a new head gaskets. What would you recommend? So far I had FelPro 1043, which is a bit thinner for higher CR. I would like to keep that. It's also smaller in diameter, which is better I think. Only problem is that I thinjk it's steel wire gasket and it made some markings in the heads.
What do you use? I need a quality gasket. Thanks. |
Posted on: 2013/10/18 8:31
'90 L98 auto with a lot of mods |
Matatk | Re: Which head gasket | ||
What was wrong with the fel pro?
Posted on: 2013/10/18 13:09
sliding | Re: Which head gasket | ||
The problem wasn't in the gasket. It was a crack in the head that started the process. But after examining the head I saw that gasket made too deep marks. I think it's because #1043's have steel wire rings. And #1010's are with copper wire rings.
Posted on: 2013/10/18 18:09
My car I would run felpro. If you want to spend more to feel better, buy cometics.
Perhaps look through the online catalog and see if they have a thickness that suits your needs. Will might be able to give you a specific recommendation. |
Posted on: 2013/10/18 19:39
