256 user(s) are online (178 user(s) are browsing Forums)
Transverse Leaf Spring
matts85vet align auto trans with block?
Toledo, Ohio
58 Posts
block is back from rebuilders and back in the car. i have the 700r4 bolted up to the block with the 6 bolts and the 3 flexplate bolts connected to the crankshaft. i noticed that the trans is slightly to the passenger side by about 1/32"
it's on the dowel pins. didn't notice how it was before i removed the engine.
my question is does it matter if the outside shell of the trans is a little off as along as everything bolts up ok and it's on the dowel pins? or do i need offset dowel pins, or is that only needed for manual transmissions.
thanks in advance!
Posted on: 2014/2/6 3:56
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
bogus Re: align auto trans with block?
could there be debris in the hole or on the pin? seems odd to me, but it could also be age or a warping of the trans case...
Posted on: 2014/2/6 16:32
BrianCunningham Re: align auto trans with block?
Sure it's your transmission case?
Posted on: 2014/2/6 20:20
Personally, I would bet on a bet trans case ahead of a bent block face... cast iron vs aluminum?
Posted on: 2014/2/6 20:42
When it's on the pins is the shaft on the trans aligned with the crank?
Take some measurements with the trans off.
Posted on: 2014/2/6 21:03
matts85vet Re: align auto trans with block?
Toledo, Ohio
58 Posts
thanks for the replies! i think i will unbolt everything and try again. is it possible to install the transmission dowel pins wrong? maybe they are bent? i just tapped them in w/a small hammer into the block. maybe they are not out far enough
Posted on: 2014/2/7 2:08
