BV85 | Wider Wheels | ||
Need some help on installing wider wheels on rear of C4.TIA
Posted on: 2014/2/7 6:38
bogus | Re: Wider Wheels | ||
what kind of help?
Posted on: 2014/2/7 6:44
BrianCunningham | Re: Wider Wheels | ||
I run 335's on all 4
What do you need? Street? Track? Drag? |
Posted on: 2014/2/7 18:17
Schrade | Re: Wider Wheels | ||
I was about to post BC had 335's on all the corners... You still doin' Linux OS on your pc's there Brian? |
Posted on: 2014/2/9 16:54
Except for the one that run SolidWorks yes
great OS |
Posted on: 2014/2/9 17:31
Only thing I do in Windows is DataMaster, if I ever learn navigation...
(not tryin' to boost your thread there, OP) |
Posted on: 2014/2/9 19:12
