254 user(s) are online (216 user(s) are browsing Forums)
Schrade Here we go again; injector install...
Money I'll never get back - new injectors.
(car will be listed F/S upon completion)
Timed Static Fuel Pressure leakdown video and breakdown startup...
https://www.youtube.com/watch?v=RAf6Itb0r2Q
Drain some coolant.
TB + some other hardware out of way.
A PUDDLE of gas atop #2 secondary intake.
Wicked out with a paper towel, and POOF!
jpg  IMG_8507c.JPG (817.55 KB)
1687_5771ccac137a0.jpg 2264X1698 px
jpg  IMG_8508c.JPG (973.08 KB)
1687_5771cd32aebbf.jpg 2264X1698 px
jpg  IMG_8527c.JPG (765.01 KB)
1687_5771ce2feb003.jpg 2664X1998 px
jpg  IMG_8530c.JPG (791.58 KB)
1687_5771ce9d99574.jpg 2664X1998 px
Posted on: 2016/6/28 0:35
Edited by Schrade on 2016/6/28 1:10:59
Matatk Re: Here we go again; injector install...
Glad you found the problem!
Posted on: 2016/6/28 3:48
Schrade Re: Here we go again; injector install...
Leaker caught in the act:
https://www.youtube.com/watch?v=OBMmn50pwzU
The leak STOPPED at 1:09, not increased, when I re-primed the rails. Jon FIC said cause the INJ disk rotated to seal point (like it's ALWAYS supposed to be)
How do you embed vids here Matt?
jpg  IMG_8513c.JPG (988.76 KB)
1687_5772ea6303881.jpg 2600X1950 px
jpg  IMG_8514c.JPG (896.02 KB)
1687_5772eaf440b98.jpg 1725X2300 px
Posted on: 2016/6/28 21:24
Inside [clean] work.
Pull ignition module. Wipe heat sink paste. Bag Ig Mod. Plenum to car wash.
Car wash jet wand to EVERY orifice / port in plenum. Safety glasses, and keep yer mouth SHUT!!!
And wash off plenum before carwash...
jpg  IMG_8531c.JPG (984.68 KB)
1687_577317b1c061a.jpg 2136X2041 px
jpg  IMG_8532c.JPG (911.35 KB)
1687_5773181328a4f.jpg 2384X2033 px
jpg  IMG_8537c.JPG (948.62 KB)
1687_577318afa54a2.jpg 2264X1698 px
Posted on: 2016/6/29 0:36
Very interesting video. I was able to see the leak on the screen. What did you have to remove to get access for the camera lead?
As far as embedding - when you go to youtube, hit share, and then select the embed option and paste it in:
Posted on: 2016/6/29 10:40
Had to yank plenum here Matt; INJ's are buried.
To the car wash.
No matter WHERE you stand, when you stick the wand in ONE hole, ANOTHER hole is pointed right in your mug. PTHAHHH...
Grease-free, and Shop-Vac all the holes. (local water like is Campbell's Soup - Chunky Style; drink it with a fork)
Ig Module cleaned and bagged; ready for new heat sink paste.
Posted on: 2016/6/29 11:57
Edited by Schrade on 2016/6/29 12:17:03
Shop-Vac loose debris. Pull INJ connectors, bag connector harnesses. INJ interfaces clean + di-electric grease.
And pull INJ clips!
jpg  IMG_8548c.JPG (894.31 KB)
1687_577420f090e3e.jpg 2264X1698 px
jpg  IMG_8557c.JPG (783.42 KB)
1687_57742177248cd.jpg 2364X1773 px
jpg  IMG_8554c.JPG (988.09 KB)
1687_577422019255b.jpg 2464X1848 px
jpg  IMG_8559c.JPG (914.63 KB)
1687_57742373dbf7e.jpg 2364X1773 px
Posted on: 2016/6/29 19:31
BrianCunningham Re: Here we go again; injector install...
real neat seeing how that goes together
Posted on: 2016/6/29 19:55
Separate the rails, prep for a gusher, rock gently (don't forget the line retainer), and removed.
Now, wait for some gas to evap, and Shop-Vac more debris.
jpg  IMG_8563c.JPG (824.61 KB)
1687_5774367e4f187.jpg 2364X1773 px
jpg  IMG_8564c.JPG (769.17 KB)
1687_577436c1414c1.jpg 2464X1848 px
jpg  IMG_8565c.JPG (838.82 KB)
1687_5774375a83d27.jpg 2464X1848 px
jpg  IMG_8570c.JPG (865.32 KB)
1687_57743827dec2f.jpg 2364X1773 px
Posted on: 2016/6/29 21:05
Just be careful of the o rings on that rail...ask me how I know
Posted on: 2016/6/30 3:14
O-Rings. Pffttt... this thing ain't scared of an O-Ring (not wile already running anyway) - ask ME how I know THAT!!!
Funny story too - was doing FINE tuning on it 2 years ago, and I misunderstood steps on other Boards; "test something, running, then pull IAC, and observe again for difference".
(he didn't insert 'shutdown', between 'running,', and 'then pull IAC'.
I know motors, but didn't know much of LT-5, so I did it, and I observed - a couple things...
I observed the IAC O-Ring get sucked into the hole, along with a big RPM INcrease.
Only a whiff of burning rubber. Gone so fast, I couldn't get to the back of the car fast enough to find out which bank of cylinders won the fight.
Posted on: 2016/6/30 13:26
jpg  IMG_8574c.JPG (889.91 KB)
1687_57753d4dde777.jpg 2364X1773 px
Posted on: 2016/6/30 15:40
A DREMEL??? ARE I CRAZY???
Nylon brush on Dremel; polish the INJ rail ports.
jpg  IMG_8578c.JPG (792.99 KB)
1687_5776bf2072271.jpg 2364X1773 px
jpg  IMG_8577c.JPG (838.83 KB)
1687_5776bf6519b31.jpg 2464X1848 px
Posted on: 2016/7/1 19:07
Santa came!!!
Here we go...............
jpg  IMG_858x.jpg (279.98 KB)
1687_577806bd1e3fc.jpg 2048X1536 px
Posted on: 2016/7/2 18:24
Clean up INJ ports:
Posted on: 2016/7/3 14:24
You can't see it from there; need to bring tools and start wrenchin' on other side of motor here Resized Image
Posted on: 2016/7/3 17:44
Smoke? Burning rubber?
Ya' gotta' take the O-Ring OUT, before polishing it.
Couldn't see too well, and started the Nylon-Brush Dremel in #2. Smoke and the smell. No wonder I couldn't get 'in the groove'...
(NO - NO VIDEO LOL)
Rest done, now to the store for more Q-Tips, port swabdown.
Posted on: 2016/7/3 18:39
Port wipedown, cont'd...
Pull tape back, Shop-Vac to ports.
LAST PIC Q-TIP IS AFTER FINAL GROOVE PASS!!!
jpg  IMG_8585c.JPG (802.86 KB)
1687_577968fbe1552.jpg 2564X1923 px
jpg  IMG_8586c.JPG (846.36 KB)
1687_5779699782f5e.jpg 2264X1698 px
jpg  IMG_8587c.JPG (804.83 KB)
1687_577969dc7c392.jpg 2464X1848 px
jpg  IMG_8588c.JPG (873.08 KB)
1687_57796b650fa9d.jpg 2364X1773 px
Posted on: 2016/7/3 19:47
Posted on: 2016/7/3 22:05
Some very careful work there. Who are the injectors from?
Posted on: 2016/7/4 3:35
Got them from Jon @ FIC. Really helpful. In-depth chats long ago on CF (revenue generation stuff, with him and admins there). Jon remembers.
THen they locked me out for argument with a mod - think I've told that story a few times here.
more stuff:
"Careful work"? It's closer to obsessive Matt; been called that half a dozen times. Makes it easier to sell when the time comes tho'...
Posted on: 2016/7/4 11:33
note; #8 Primary INJ Harness Connector snaps onto INJ, retainer clip flares and snaps in both sides, but it is NOT locking on...
Posted on: 2016/7/4 14:15
Leakdown test.
Cross your fingers. Cross your eyes, your teeth, your hair, toes; CROSS 'EM ALL....................
edit:
Primed to 51, compress air in lines, slow drop to 49 after a few minutes...
Posted on: 2016/7/4 14:52
Edited by Schrade on 2016/7/4 15:08:24
Schrade wrote:
Leakdown test.
Luck sent
Posted on: 2016/7/4 15:04
STILL AT 45 POST 5 MINUTES (AIR DECOMPRESSING, PUMP CHECK VALVE HOLDING ??? )
EDIT:
8 MINUTES; STILL 44 PSI!
Posted on: 2016/7/4 15:10
Rails re-primed; air in rails compressed, then DE-compressed, and STILL HOLDING 46 PSI POST :30 MINUTES.
VICTORY!!!!!!!
(videos uploading for rail / INJ assembly re-wind)
She's FOR SALE $1?,???
Posted on: 2016/7/4 16:49
Re-wind on assembly...
Posted on: 2016/7/4 21:32
More assembly (rewind):
Posted on: 2016/7/5 12:38
Leakdown + 22 hours = 31 PSI; that's a GO.
Dry fit plenum good, Ig Mod emplacement good...
(and momma House Wrenn is waitin' for me to finish up, so that MY 5 little wrench-helpers won't get Shanghai'd into slave labor ( 2 days old, I think) )
jpg  IMG_8590c.JPG (836.77 KB)
1687_577bc3aa411e2.jpg 2464X1848 px
Posted on: 2016/7/5 14:32
note 2; Primary MAP Sensor Mounting Bracket is binding upon twin PCV cap; shimmed ATM.......
edit:
addressed; in order.
Posted on: 2016/7/5 17:28
Edited by Schrade on 2016/7/5 17:45:33
note 3; for initial startup, I have installed another 'ticket stopper' gasket, between TB, and Air Horn.
I determined during top end rebuild 2 years ago, that the Secondary Port Throttle butterflies leaked, preventing the 'zero'd ' idle RPM's, and all other Closed Loop op parameters matching up with OEM spec.
A fabbed gasket compensated for this (I could see NO sunlight around the SPT butterflies; none-the-less, idle vacuum pulled air).
IAC correctly adjusted, but not fast enough to hold <75 RPM swing at CL idle.
The ticket stopper held CL idle <25 RPM swing.
After confirmation of zero'd idle, it's out for OEM gasket...
jpg  IMG_8600c.JPG (911.43 KB)
1687_577bf7d01c447.jpg 2364X1773 px
Posted on: 2016/7/5 18:09
Spool up; she is running like a top.
Vid on the way...
Posted on: 2016/7/5 22:00
Congrats!
Posted on: 2016/7/6 0:44
Thanks there Brian...
Posted on: 2016/7/6 19:57
