257 user(s) are online (205 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
Schrade Optima top post problem...
Couple of ya' probably already know the problem - what did you do to work around it?
Options are:
Cut the (+) post down.
Notch the bracket that the post is in contact with.
Shim the battery so it is tipped forward.
The bracket had just gouged the (+) post plastic cover, and he was gettin' ready to plug it in. CLOSE call - woulda' been a BAD scene.
First thing we thought of was shimmin' the tray. But every tray bolt is off-plane with the battery, so that won't work.
Then we tried the shim method at the Advance / Zone. The clamp bolt at the rear of the battery base is long enough to still clamp the battery, if it is shimmed up about 3/8", which is how much is necessary for the post to be off of the bracket.
He cut up the adapter bracket, and it gave only about 3/16". Didn't get it, so we put my battery back in, and I'm listenin' for other suggestions...
How did you do yours?
Posted on: 2008/9/22 20:31
biggrizzly Re: Optima top post problem...
Chuck,
I never have used the Optima, just because of the issues you are having. However, MrMojo had a thread a long time ago where he cut off the posts enough for clearance and then insulated them.
I'm not sure there is much to gain from the Optimas unless you have a ton of vibration, then you will need a better battery mount anyway.
Posted on: 2008/9/22 20:56
pianoguy Re: Optima top post problem...
I've read mostly about the cutting the post method. One of the reasons I like my cheap Fleet Farm side-terminal battery ;-)
Posted on: 2008/9/22 21:58
:me2:
WalMart for me
Posted on: 2008/9/23 0:53
VetteUSA Re: Optima top post problem...
103 Posts
I just filed the post down some. enough for clearance from that bracket.
Posted on: 2008/9/23 2:13
Schrade Re: Optima top post problem...
Takin' down the post seems the concensus.
But, if it turns out to be bad for any reason, will warranty be a problem?
What kind of physical load does that bracket support - the one with that horn-lookin' gig on it, next to the PCM?
Anybody know? What is that thing anyway???
Posted on: 2008/9/23 3:42
I took it back.
I can't hack my brackets, and if I hack the battery, the warranty is void, so they said. I bought an Autocraft Titanium.
Cheapie? Hardly. $82.:surprised
Posted on: 2008/9/24 0:25
CorvetteArchives Re: Optima top post problem...
65 Posts
OR you can JUST BUY a 78 series Optima that doesnt have the top posts!!
I saw it 3 days ago at A&A auto parts, a local speed shop chain here in PA.
Posted on: 2008/9/25 18:28
