WW7 | Question on Wheel size? | ||
Will running 17" wheels on the front and 18" wheels on the back of my 89 coupe look funny? Also will it throw off my speedometer? WW
Posted on: 2008/12/24 18:18
CentralCoaster | Re: Question on Wheel size? | ||
Only the actual tire diameter effects the speedometer.
All the standard fitments for your 17 or 18" wheels will have about 25-26" diameter, which is fine for speedo accuracy. I've seen C4s with 18s on back, it looks fine. On a C5 its almost necessary to match the huge ass end. I prefer to keep them equal all around for the sake of tire rotations. If you have different wheel sizes and directional tires, you can't rotate anything. |
Posted on: 2008/12/24 18:23
BrianCunningham | Re: Question on Wheel size? | ||
18f/17r same tire diameter
Posted on: 2008/12/24 18:25
WW7 | Re: Question on Wheel size? | ||
Man, you guys sure give answers quick... Thanks WW
Posted on: 2008/12/24 18:28
What wheels are you looking at running?
Posted on: 2008/12/24 18:29
these are from OEwheels.Morxchn chrome deep dish Corvette C5 style wheels.They also come in just 17" and thats probably what I will get.Do you like the looks of them?
Attach file: oe-vette-c5-18-dd-c-rw-1ps.jpg (141.80 KB) |
Posted on: 2008/12/24 18:48
Very cool Haven't seen that design before. I like it better than the stock C5 wheels. Too bad they don't have offsets for the 84-87 cars.
Here's a better shot. |
Posted on: 2008/12/24 23:29
jdtireman | Re: Question on Wheel size? | ||
When you buy your tires, just make sure that the overall diamtere for both front and rear is within 5% +/- of 25.7 inches (OE size). You could stick with the stock 275/40ZR17 on the front and go 315/35ZR18 on the rear. OD's will match and look slick.
Posted on: 2008/12/27 19:45
