132 user(s) are online (75 user(s) are browsing Forums)
Mr_Mojo Mr Mojo's 10th Annual Delaware Crab Trip
Lakewood,NJ
225 Posts
This event is open to all folks with any type car from any forum.
Date is June 20, 2009.
I will post more details as the date gets closer, but it will pretty much follow the previous 9 years.
We will cruise the backroads of coastal Delaware, do some go kart racing in Rehoboth and then end it with another backroad tour of southern Delaware and all you can eat crabs in Delmar,DE.
If you are interested, please post up so I can start a head count.
Meet points will be determined as we get closer to the date.
Posted on: 2009/1/23 21:29
BrianCunningham Re: Mr Mojo's 10th Annual Delaware Crab Trip
I'll see if I can make it down there.
Posted on: 2009/1/23 21:52
NC Kid Re: Mr Mojo's 10th Annual Delaware Crab Trip
North Carolina
1671 Posts
This probably sounds bizzare but my father and I will try to tag along. He is out of work at the end of Janruary. Cars running good and he is on a severence package. He seems interested. Will confirm as date gets closer! Im excited.
Posted on: 2009/1/23 22:31
