donandsandra | Digital Dash Problem | ||
Anybody seen a digital dash problem like this before? Ive been pulling my hair out trying to figure this out!!!!!!
I turn the key on the dash display looks great... Start the engine and the cluster goes goofy... Check the video below. http://www.youtube.com/watch?v=qdULEgJT8kw Thanks Don __________________ Vrooom nothing compares to a VETTE!!! Save the wave!!! |
Posted on: 2006/12/17 19:57
PeteK | RE:Digital Dash Problem | ||
The digital dash is prone to poor grounds. Gordon Killebrew has a book take explains how to run a new ground by tapping the ambient air temp switch mounted on the firewall, behind the brake pedal area. Hopefully someone with the book will chime in.
Posted on: 2006/12/17 20:12
red_johnny | RE:Digital Dash Problem | ||
This happened to me before with low voltage and a bad alturnator. I would check it out and get it tested.
Posted on: 2006/12/17 21:44
donandsandra | RE:Digital Dash Problem | ||
Thanks Guys for the great info.... I will have the alternator checked out.... if that dont work I will order the book.
Thanks A Million!!!! |
Posted on: 2006/12/18 1:14
Let us know how it turned out then.
Posted on: 2006/12/18 1:21
Just repaired problem..... It was a bad coil... that was a weird problem...
Posted on: 2006/12/19 2:39
A bad coil, ignition coil?
Posted on: 2006/12/19 14:39
Yes ignition coil.... I replaced the coil last year. Car was in the paint shop for 7 months.. got it back and it had the problem.... I keep a list of everything I do to the car.. The last thing I did was replace the coil... Put the old one back in problem went away.... weird problem..
Posted on: 2006/12/20 14:34
WOW, that is a strange problem
Posted on: 2006/12/20 19:11
freakd | RE:Digital Dash Problem | ||
bad coil, thiat is interesting
anychance of you doing a tech tip for us??? :thumbright: |
Posted on: 2006/12/26 13:09
