TommyT-Bone | 1990 Fuel Pump Relay Location | ||
I have a 90 and a 91 but my FSM is for a 91. Can somebody please point me to the location of the fuel pump relay on a 1990 coupe, 6 sp, L98. In the 91 the fsm says it's on the passenger side under the dash. Where is it on the 90? I dropped the passenger side panel but I didn't see it. Maybe I wasn't looking in the right place. Thanks.
Tommy T. |
Posted on: 2009/6/28 19:32
BillH | Re: 1990 Fuel Pump Relay Location | ||
Aren't they under there close to the center (left side of the pass dash)? On my 92 there's a bank of 5 relays there.
I thought someone said the 90/91's where there too. |
Posted on: 2009/6/28 19:59
TommyT-Bone | Re: 1990 Fuel Pump Relay Location | ||
I dropped the panel again. I'm going to search again a little more aggressively. I'll check back shortly.
Posted on: 2009/6/28 20:11
Left side about 1 inch up on the dash panel. Thanks Bill.
Posted on: 2009/6/28 20:24
bogus | Re: 1990 Fuel Pump Relay Location | ||
Cool. I am with Bill on this one, too. I thought when the dash was redone in 1990, that the relays were all moved under the left knee pad.
Glad you found'm!!! |
Posted on: 2009/6/28 20:41
But the problem continues. No fuel rail charge . No fuel to the injectors.
Posted on: 2009/6/28 21:40
does the pump fire?
Posted on: 2009/6/28 21:48
I'm working in that direction. Fuse is OK and changing the fuel pump relay did nothing. At this point, I know it has spark, the fuel rail will not charge and the engine will sputter and die on first attempt after sitting awhile. The oil pressure guage does climb on start attempts.
Posted on: 2009/6/28 22:02
hm... interesting...
What is the age/condition of the fuel filter? just curious. Do you have 12v at the pump harness? |
Posted on: 2009/6/28 22:20
Fuel filter is 6 months old less than 500 miles. I'll have to check the voltage at the harness tomorrow.
Posted on: 2009/6/28 23:28
vetteoz | Re: 1990 Fuel Pump Relay Location | ||
Pull the codes
'90 has the lovely CCM and SIR (airbag ) systems that have to send a data signal to the ECM to fire the injectors (and run pump from memory). |
Posted on: 2009/6/29 0:45
CCM is the VATS... it would stop the car from cranking, too.
SIR has little or nothing to do with starting. If it does, then I have misread that section... so I guess I will dbl check it... yea, I just checked it. SIR circuit diagram show nothing to connect it to the VATS or starting process. |
Posted on: 2009/6/29 1:05
monsterstoys | Re: 1990 Fuel Pump Relay Location | ||
Did you ever SOLVE the problem of it NOT STARTING when it was warmed Up ? My 90 runs rough & sputters when warmed up.
I changed ALL sensors and ECM , and the car still will not start when it is warmed up. It has Spark , NEW Fuel pump but it seems like theres no fuel. The filter is clean & good with NO obstructions. PLEASE HELP !!!!!! |
Posted on: 2010/10/16 4:31
Posted on: 2010/10/16 4:35
started a new thread |
Posted on: 2010/10/16 9:59
I must add... I was WRONG on the SIR... if the fuse is blown, it will kill power to the ECM.
Posted on: 2010/10/16 15:39
