190 user(s) are online (100 user(s) are browsing Forums)
klkordzi Head bolt question
Pittsburgh, Penna
152 Posts
I'm in the middle of swapping the heads on my 85 and wanted to chase the threads for the head bolts but I'm having trouble finding a tap. I believe the bolts are 11m x 1.75. Does anyone know if this is correct?
Posted on: 2009/7/6 0:02
klkordzi Re: Head bolt question
Pittsburgh, Penna
152 Posts
Never mind. I assumed the bolt was metric but right after writing the post I did a little research on Summit and saw that all bolts for 76 to 2000 were the same. Went out to the garage and found they were just plain old 7/16 inch bolts.
Posted on: 2009/7/6 1:06
Durango_Boy Re: Head bolt question
Don't use a real tap. Use a specific chaser tool. They cut totally different and you don't want to compromise the integrity of those bolts. I would also suggest ARP moly bolts at the very least.
Posted on: 2009/7/6 3:08
BillH Re: Head bolt question
It's amazing how much you use a set of chasers after you buy them, especially on engines.
This one's from Craftsman.
jpg  IMGP0520.jpg (0.00 KB)
Posted on: 2009/7/6 12:57
biggrizzly Re: Head bolt question
I bought the same set when I did my engine. Even though I only used a couple of the chasers they will definitley come in handy in the future and the set is not that expensive if I recall.
Posted on: 2009/7/6 13:03
Yep, I run every threaded hole on a bare block with these before any assembly.
IIRC, this set was on sale for $39, it has course/fine SAE and metric.
Posted on: 2009/7/6 13:21
