252 user(s) are online (194 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
Midnight85 Paging Pete K, squeak, part 2
Streator, IL.
264 Posts
Hi Pete,
I was finally able to get the time to get the trans out of the car, there is nothing wrong with the front pump including the rotor. The only thing I found wrong was the small cone shaped mesh filter that goes into the side of the pump was not snapped it place. It wouldn't snap into place so I replaced it with another one I had. No shavings anywhere in the pan or otherwise. Can it be the torque converter? Externally the converter looks perfect so where do I go from here?
Posted on: 2009/8/18 2:00
PeteK Re: Paging Pete K, squeak, part 2
I have never (yet) seen a torque converter squeek.
Take the converter to a local trans shop and ask them to measure the end play. If it is excessive, swap it out.
Posted on: 2009/8/18 2:07
