BrianCunningham | C3 diff in a C4? | ||
Ok here's thought
You can put a 12bolt diff in a C3 Corvette center section. Tom's differential has all the parts can can build 7 seccond NHRA legal setup. A Bulletproof '63-'79 Corvette IRS Setup That's NHRA-Legal To 7.50S http://hotrod.automotive.com/79266/05 ... ette-irs-setup/index.html I was at a Corvette shop last night and measured up a C3 diff, which was very similar with wise. I know people make adapters to go from a D36 to a D44. I'm wondering if I can make one to go from a D44 (or a D36) to a C3 thought? |
Posted on: 2009/9/22 13:35
bogus | Re: C3 diff in a C4? | ||
with any amount of welding, sure, anything will fit anything... but I feel the D44 is better than the 12 bolt.
I prefer the Ford 9" if you want to go drag racing. But for road racing, I would just get the D44 built right and be done with it. |
Posted on: 2009/9/22 13:53
vetteoz | Re: C3 diff in a C4? | ||
I don't see why not; but would you not use only the modified 12 bolt C3 center with the C4 spindles and dogbones? |
Posted on: 2009/9/22 13:58
BrianCunningham | Re: C3 diff in a C4? | ||
exactly what I was thinking |
Posted on: 2009/9/22 16:14
anesthes | Re: C3 diff in a C4? | ||
Other than the weak clutch packs, laughable aluminum housing, smaller ring gear size, and axle design that breaks under wheel hop the dana44 is great. -- Joe |
Posted on: 2009/9/23 1:45
yea, but he ain't drag racing.
Posted on: 2009/9/23 3:01
Oh.. dang.. my bad. Then why go through the effort of retrofitting ANYTHING? I keep forgetting he does that road course stuff. -- Joe |
Posted on: 2009/9/23 10:10
Actually I do, but people with high HP cars are breaking them at autocrosses as well http://forums.corvetteforum.com/c4-te ... rear-end-broke-again.html |
Posted on: 2009/9/23 13:40
