jsup | Rocker Arm Adjustment | ||
This is the first motor I did that required measuring the push rods.
My last build used stock heads, so I used stock pushrods. Anyway, let me know if these are right, by the pics. Thanks. ![]() ![]() ![]() ![]() ![]() |
Posted on: 2008/1/5 2:21
biggrizzly | RE:Rocker Arm Adjustment | ||
Based on the photos that Lloyd sent me you are looking good. It is hard to actually see the contact area of the roller tip on the Valve stem. It should be centered.
Posted on: 2008/1/5 2:26
bogus | RE:Rocker Arm Adjustment | ||
What locks those bolts to the studs? I would be concerned with those walking off.
I don't recognize that brand... so I may be speaking from total ignorance... just sharing an observation. |
jsup | RE:Rocker Arm Adjustment | ||
What locks those bolts to the studs? I would be concerned with those walking off. Those are Comp Cam full roller Pro Mags. They are Chro Mo which is stronger than Aluminum. The nuts have an allen key lock down in the center of them. http://www.compperformancegroupstores ... amp;Category_Code=ROCKARM |
Posted on: 2008/1/5 2:35
ah, ok. I didn't see the allen locks! Cool!!!
Posted on: 2008/1/5 2:38
So how does the geometry look? Anyone......
FYI, from Summit... http://store.summitracing.com/partdet ... 302%2D16&autoview=sku * The strength of steel, the light weight of aluminum. COMP Cams Pro Magnum roller rocker arms combine the strength of 8650 chromemoly steel and the weight savings of aluminum rockers. COMP Cams took advantage of computer design to simulate the stresses that affect rockers under various operating loads. This allowed the engineers to lessen the rockers' mass at non-critical areas, and strengthen the areas that take the most punishment. The results were rocker arms that are strong where they need to be, and actually weigh 5 percent less at the valve than comparable aluminum rockers. [B] |
Posted on: 2008/1/5 2:42
Same rockers I'm using. Nice stuff
Posted on: 2008/1/5 2:57
Alcee1 | RE:Rocker Arm Adjustment | ||
![]() I agree, nice stuff |
Posted on: 2008/1/5 3:05
Edlebrock Heads, 2030 cam, X-ram w/EGR, 1.6 R/R, Bored TB´s, AFPR, Pro-built Tranny, Vigilantly 2600, Transgo, Dana 44 3.54, Hardened Pushrods & Head Bolts, Custom performance chip, K&N, Double roller timing chain, Aluminum radiator & flex hose, MS |
dan0617 | RE:Rocker Arm Adjustment | ||
I used Summit self aligning rockers and eliminated my guideplates. My 113 heads are shaved and I'm running a .024 headgasket so I bought 7.15" trickflow chromemoly pushrods instead of the stock 7.2". My roller to valve tip location look the same as yours and I think I'm fine, so I think you are fine. My summit rockers appear to use the same nuts/locks. The real question is are you sure you found 0 lash correctly? It is easier for me to find it when the intake is off and you can see the pushrod to lifter contact. How many turns past 0 lash did you go for preload? The geometry looks good to me from the pics, if you got the preload right you should be fine.
Posted on: 2008/1/5 15:49
I osted this over at the dark side a while ago. It might help.
[web]http://www.biggrizzly.com/Lloyd_words.html[/web] |
Posted on: 2008/1/5 15:58
Notorious | RE:Rocker Arm Adjustment | ||
Same rockers I'm using. Nice stuff :me2: Many thousands of miles of trouble-free service. |
Posted on: 2008/1/5 15:59
I'm going to re adjust with the motor running. That's really the best way.
No need to go more than 1/2 turn past zero lash. That I do by "feel". So somewhere between 1/4 and 1/2 turn. CFI-EFI posted a good way to lock them down, I'll be using his method. |
CFI-EFI | RE:Rocker Arm Adjustment | ||
It is impossible to make a judgment as to the push rod length from the
pictures posted. As biggrizzly's second post points out, the correct length rod is revealed in the path the rocker arm roller traverses during a cycle. Your snap shot doesn't show the pattern. At best, it just shows the position at some arbitrary, unknown, point in the travel. Especially in the top two photos, are the Allen headed set screws installed? If so, they look set awfully deep into the adjusting nut. If the screws are in there and the preload is anywhere near where it will end up, I would remove an adjusting nut to see how many threads of the stud are engaged by the nut. My guess, from what I can see, is not enough. Based on a photo, and not being there, I'm guessing you need rocker arm studs that are about a 1/4" longer. Maybe I'm wrong and it's just the pic, but it's a lot cheaper to check, now, while it's going together than to check to see why the adjusting nuts stripped out and flew off of the studs, later. RACE ON!!! |
Posted on: 2008/1/5 22:38
It is impossible to make a judgment as to the push rod length from the Thanks. I have about 1/2 inch of thread into the nylocks. It seems the nylocks are awfully deep. The entire valve train is Comp Cams. |
Posted on: 2008/1/6 14:40
CasetheCorvetteman | RE:Rocker Arm Adjustment | ||
Nylok is a type of nut you simply will never find in a valve train. Its the type of locking nut that has a nylon washer built into it, and in an ideal world, this creates enough friction to prevent the nut from working loose.
Posted on: 2008/1/6 14:49
Nylok is a type of nut you simply will never find in a valve train. Its the type of locking nut that has a nylon washer built into it, and in an ideal world, this creates enough friction to prevent the nut from working loose. I miss spoke. I meant lock nuts. ![]() |
Posted on: 2008/1/6 15:19
CFI is right (and hi CFI, good to see you
Posted on: 2008/1/6 16:32
CFI is right (and hi CFI, good to see you I have done some research. There seems to be different sizes of lock nuts. Some are deeper than others. I have 1/2 inch of thread covered, which should be plenty. I suspect these nuts are made to use with girdles. |
Posted on: 2008/1/6 17:03
FATED | RE:Rocker Arm Adjustment | ||
Just 2 Cents. I think you need a push rod length checker. I don't think you can adjust the valves when it is running unless it is pre 70. It will idle fast and squirt oil everywhere.
Posted on: 2008/1/6 20:37
Just 2 Cents. I think you need a push rod length checker. I don't think you can adjust the valves when it is running unless it is pre 70. It will idle fast and squirt oil everywhere. I purchased the length checker and used it. I'm just double checking my work. When I color the top of the valve with a marker the marks are very slightly outside of center, and are less than .080. Right in spec. Other thoughts don't hurt. |
Posted on: 2008/1/6 21:32
j3studio | RE:Rocker Arm Adjustment | ||
Good reading - a "people who know stuff" thread.
Posted on: 2008/1/6 21:37
What length studs did you buy? I'm getting ready to order a set of ARP studs and don't know if I should go with the 1.75 or 1.89 length?
Posted on: 2008/1/7 17:40
What length studs did you buy? I'm getting ready to order a set of ARP studs and don't know if I should go with the 1.75 or 1.89 length? They came on the heads.... |
Posted on: 2008/1/7 22:02
ninetyfivevette | RE:Rocker Arm Adjustment | ||
I just pulled Pro Mags off ARP studs on my heads- this may be silly, but did you put the nut in the pocket of the fulcrum? You'll get what you're seeing if you're on the other side (round).
Here is a pic that shows what mine looks like, though unfortunately it is zoomed in a fuzzy, but you'll get the idea. Pic here |
Posted on: 2008/1/8 6:05
