| Schrade | No Tech 1 yet; A/C Head Unit Display 'code' | ||
I have intermittent H74 LED Dimming Circuit Open or Shorted. I ALSO have a CONSTANT - --- --- pic below, on A/C Control Head (should be --- --- ---), for E & C Bus Failure. Neither diagnostic flow chart defers to anything related to the other (that I see yet). Does this pic look like it could be 3 identical dashes? |
Posted on: 2015/12/29 18:27
Transfer
| GRIS | Re: No Tech 1 yet; A/C Head Unit Display 'code' | ||
THAT'S HOW THE AC CONTROL HEAD ON MY '96 LOOKED WHEN IT DIED. |
Posted on: 2015/12/29 20:39
REMEMBER THE GOOD OLD DAYS WHEN NOUNS HAD GENDER AND PEOPLE HAD SEX? ---"yellow is for folks who think a bright red Corvette is too restrained." |
Transfer
| Schrade | Re: No Tech 1 yet; A/C Head Unit Display 'code' | ||
I wish. But I have issues with radio head unit too...
Posted on: 2015/12/30 2:33
Transfer
| BillH | Re: No Tech 1 yet; A/C Head Unit Display 'code' | ||
Schrade, I've had the same code for 10 years. I haven't looked in the FSM lately (cause I don't care anymore)but IIRC it's the circuit that dims the dash when it gets dark out. There's a sensor on top of the dash that reads ambient light for that circuit. I've never seen this cause a problem, dash dims like it's supposed to. So, I ignore it. Clear it when I check codes but it always comes back. Good luck with the A/C stuff. |
Posted on: 2015/12/31 15:10
Transfer
| bogus | Re: No Tech 1 yet; A/C Head Unit Display 'code' | ||
If the AC head has died, Dr Dons can fix... my bigger concern is the AC Programmer...
Posted on: 2016/1/5 0:18
Transfer
Besides the A/C LED Code - pic above, my blower is running constantly.
And radio is inoperative, along with A/C head Unit. Haven't pulled the dash yet, which is necessary in all 3 diagnostic flow charts. I've read all 3 flow charts to the end, looking for convergence to common source. It SEEMS to be CCM, but I have to know for sure. Back-probing circuits is the hardest job I think, above motor pull, tranny pull................... Non defer to other symptoms, for FIRST diagnostic, which occurs often with multiple DTC's..... |
Posted on: 2016/1/5 21:29
Transfer
No common ground faults?
The CCM might fail, but I would be surprised if it caused those items to fail. The CCM monitors, for the most part, not controls. |
Posted on: 2016/1/5 22:06
Transfer
CCM ground was part of Top End Resto:
CCM grounds (Yellow circle) got same treatment as ground in hand - cleaned, dielectric grease, re-seating. Quote:
Posted on: 2016/1/6 2:54
Transfer
Transfer
