569 user(s) are online (79 user(s) are browsing Forums)
Schrade No Tech 1 yet; A/C Head Unit Display 'code'
I have intermittent H74 LED Dimming Circuit Open or Shorted.
I ALSO have a CONSTANT - --- --- pic below, on A/C Control Head (should be --- --- ---), for E & C Bus Failure.
Neither diagnostic flow chart defers to anything related to the other (that I see yet).
Does this pic look like it could be 3 identical dashes?
jpg  IMG_7990.JPG (913.71 KB)
1687_5682d0823517e.jpg 3184X1444 px
Posted on: 2015/12/29 18:27
GRIS Re: No Tech 1 yet; A/C Head Unit Display 'code'
OKLAHOMA
8931 Posts
THAT'S HOW THE AC CONTROL HEAD ON MY '96 LOOKED WHEN IT DIED.
Posted on: 2015/12/29 20:39
Schrade Re: No Tech 1 yet; A/C Head Unit Display 'code'
I wish. But I have issues with radio head unit too...
Posted on: 2015/12/30 2:33
BillH Re: No Tech 1 yet; A/C Head Unit Display 'code'
Schrade, I've had the same code for 10 years.
I haven't looked in the FSM lately (cause I don't care anymore)but IIRC it's the circuit that dims the dash when it gets dark out.
There's a sensor on top of the dash that reads ambient light for that circuit.
I've never seen this cause a problem, dash dims like it's supposed to. So, I ignore it. Clear it when I check codes but it always comes back.
Good luck with the A/C stuff.
Posted on: 2015/12/31 15:10
bogus Re: No Tech 1 yet; A/C Head Unit Display 'code'
If the AC head has died, Dr Dons can fix... my bigger concern is the AC Programmer...
Posted on: 2016/1/5 0:18
Besides the A/C LED Code - pic above, my blower is running constantly.
And radio is inoperative, along with A/C head Unit.
Haven't pulled the dash yet, which is necessary in all 3 diagnostic flow charts.
I've read all 3 flow charts to the end, looking for convergence to common source. It SEEMS to be CCM, but I have to know for sure.
Back-probing circuits is the hardest job I think, above motor pull, tranny pull...................
Non defer to other symptoms, for FIRST diagnostic, which occurs often with multiple DTC's.....
Posted on: 2016/1/5 21:29
No common ground faults?
The CCM might fail, but I would be surprised if it caused those items to fail. The CCM monitors, for the most part, not controls.
Posted on: 2016/1/5 22:06
CCM ground was part of Top End Resto:
CCM grounds (Yellow circle) got same treatment as ground in hand - cleaned, dielectric grease, re-seating.
jpg  HPIM7310d.JPG (917.90 KB)
1687_568c81db7c32c.jpg 2148X1611 px
Posted on: 2016/1/6 2:54
