pr0zac | jeep question | ||
i remember a thread about jeeps on here a while back and was in need of some help.. i have got a 2000 grand cherokee that is throwing a p1494 code.. i have researched it but its kinda shady on what and how to test this to find out whats wrong. anyone with any experience??
Posted on: 2009/11/18 21:25
BrianCunningham | Re: jeep question | ||
later than 1996 should be OBDII
Have you looked up the code? If so, what does it say? |
Posted on: 2009/11/18 21:41
BillH | Re: jeep question | ||
Searching for these fukin codes on the web is a huge pain in the ass. I went thru this on my Silverado, yea, I'm too cheap to buy the manual.
I saw this: NUMBER: 18-01-00 GROUP: Vehicle Performance DATE: Feb. 4, 2000 SUBJECT: Misdiagnosed Leak Detection Pump Systems With DTC P1494, P0442, P0455, OR P0456 MODELS: 1997 - 2000 (AB) Ram Van 1997 - 2000 (AN) Dakota 1997 - 2000 (BR/BE) Ram truck 1998 - 2000 (DN) Durango 1997 - 2000 (FJ) Avenger/Sebring/Talon 1997 - 2000 (JA) Cirrus/Stratus/Breeze 1997 - 2000 (JX) Sebring Convertible 1997 - 2000 (LH) Concorde/Intrepid/LHS/3OOMNision 1997 - 2000 (NS) Town & Country/CaravanNoyager 1997 - 2000 (PL) Neon 1997 - 2000 (PR) Prowler 1997 - 2000 (SR) ViperNiper GIS 1997 - 2000 (TJ) Wrangler 1999 - 2000 (WJ) Grand Cherokee 1997 - 2000 (XJ) Cherokee 1997 - 1998 (ZJ) GrandCherokee DISCUSSION: During evaporative system diagnosis, Leak Detection Pumps have mistakenly been replaced. A thorough inspection for pinched, kinked, or disconnected supply vacuum lines (as currently listed in the Powertrain Diagnostic Procedures) is a critical step in diagnosing DTC P1494 (LDP SW OR MECHANICAL FAULT). Additionally, the other evaporative leak faults (DTC P0442 - SMALL LEAK, P0455 - LARGE LEAK, and P0456 - VERY SMALL LEAK) should have the supply vacuum lines examined for pinches or kinks prior to any LDP component replacement. The supply vacuum lines should be checked from the engine compartment all the way to the fuel tank, including the LDP and purge system Another guy says, it may be the seal on your gas cap preventing evap pump up and setting the code. List of TSBs, jeep GC at: http://www.edmunds.com/maintenance/re ... pe=tsb&styleId=12652&zip= Good Luck |
Posted on: 2009/11/18 22:30
Matatk | Re: jeep question | ||
Check here - guy posted diagnostics:
http://www.2carpros.com/forum/2001-ot ... -code-p1494-vt119413.html Matthew PS - moved to other vehicles section. |
Posted on: 2009/11/18 23:43
pr0zac | Re: jeep question | ||
it was a rubber elbow that had deteriorated and had come off the manifold. i replaced it with a section of hose. i followed other steps to try and make sure it was nothing else. as of yet the light hasn't come back on. thanks for the info!
Posted on: 2009/11/19 21:46
See, we can help with more than just vettes! Glad you got it worked out.
Matthew |
Posted on: 2009/11/19 23:12
