pappyfreebird | any way ta run two filters | ||
on a xfire n git rid of the massive top coverin the motor..any easy hey i did it wid pix???
Posted on: 2009/9/12 2:57
Midnight85 | Re: any way ta run two filters | ||
Like I said in your other post, I don't know squat about crossfires but if you can fabricate an air filter bottom to fit the throttle body and find a way to hold them down you'd be home free. Give it a shot and be the first!
Posted on: 2009/9/12 4:16
HORSEPOWER! Some is good, more is better, too much is just right. |
CentralCoaster | Re: any way ta run two filters | ||
Check out the 82 Corvette or the 82-84 F-bodies for some ideas.
Posted on: 2009/9/12 4:57
pappyfreebird | Re: any way ta run two filters | ||
now why help me here n jump me on other one!!! cause someone else did??well any ways thanks 85 n thank you cc..thats wud i jus mentioned..nuthar motor builder sez hunt down sum single tbi unit cars n git there bottums fer the oval fit n fab fum there...
ps hey there midnight i rekon im 1st alot,,well seems i r no.1 alot mabee i gots em mixed up..dont mind fabbin me own stuff like it fer most part..hafta git me sum idears... |
Posted on: 2009/9/12 14:31
bogus | Re: any way ta run two filters | ||
I wouldn't.
The 84 xfire air box is connected to the hood, which is a cowl induction setup. If anything, the system draws cool air in and that's the best thing you can do. |
Posted on: 2009/9/13 3:32
i hear ya there bog...but wouldnt a set up like this still draw from the hood holes,,nawt direct but would be enuff flow?
it chure as L looks alot better..thids is earlier xfire Attach file: crossfire.jpg (0.00 KB) |
Posted on: 2009/9/13 16:48
Looks do not = performance.
You need to take a deep breath and reassess what you are doing. If CFI-EFI was around, and he might chime in, I suspect he would discourage it. Those cute little air breathers will only suck in warm engine air. The Xfire airbox is sealed to the hood to get cold air. If I owned an xfire engine, this is what I would do: 1. machine/hone out the intake to open up the ports to 100% and not their current 55%! That will liberate a ton of power. 2. Aluminum heads... Alcee1 has Edelbrock heads on his 84 and it really runs well with them. Also need cam and roller rockers. 3. Get your current injectors rebuilt and honed out. There are folks that can build them up to increase air flow. 4. Upgrade the computer. Others will chime in with the exact 411 (and I might find it online elsewhere). However, the idea is to update the computer with one from a pickup, c1987. The newer ECU has a better CPU for better tuning. Another option would be an entire ECU upgrade to LS1 specs with a modern sequential injection system... 5. Headers and better exhaust. I would estimate, without even getting into the guts of the engine (beyond cam), that you are looking at a motor making well over 300 RWHP. I would estimate this upgrade would cost about $3500.00. The charm is if you plan it right, it can be done over a couple of years and won't hurt as much. That is all if you want to keep the L83... as an alternative, update the entire driveline... LSx, TKO 5spd, D44. That upgrade would cost about $10k, tho... Again, this upgrade can be done over time. At least the accumulation of parts. Then take a winter to put them all in. Figure a used LS1, with harness and ECM is about $2500 (no trans) the TKO is another $3k, and the D44 another $2k. Figure another $2500 in bits and pieces. |
Posted on: 2009/9/13 17:24
dayum bro..i jus wanted ta see mo of the engine ,,not build me a race machine wahahahaha!!! i r happy wid the ol girl jus as she is,,ok so im lyun a bit there..jus keep thinkin back on 2-4 set ups n 3 deuces n such n aways looked cool,,i hear ya on what it does..but it also blocks what could be a purty motor too...rekon i r gonna git my kid ta save yer above post thou,, n toss it in vet file fer when im rich,,so this reminds me ta say hey rednecks membar ta donate ta the make pappy rich n famous foundation sosin i kin build me a beeyuchin vet rod!!
thanks again bog the paps |
Posted on: 2009/9/13 23:02
NC Kid | Re: any way ta run two filters | ||
Listen to this post....If I had, I would be alot further in performance/reliablitiy than I am now........ |
Posted on: 2009/9/14 23:51
