187 user(s) are online (132 user(s) are browsing Forums)
sliding Stock cast crank question
Zagreb, Croatia
326 Posts
How are journals on stock vette crank finished?
Is that just raw casting machined to dimensions or
are journals hardened in some way?
Posted on: 2009/10/4 13:12
dan0617 Re: Stock cast crank question
I don't believe they are hardened in any way but I'm not 100% sure. I know when my local machine shop "turns" a crank, they remove a decent amount of material from the journals then use oversize bearings to make up for it, and they do not do anything to the crank other than cut and polish it, no hardening or anything.
Posted on: 2009/10/4 15:57
bogus Re: Stock cast crank question
20861 Posts
I am unaware of any hardening, too.
Posted on: 2009/10/4 16:08
sliding Re: Stock cast crank question
Zagreb, Croatia
326 Posts
OK, thanks! I ask because some european engines have stock cranks that are nitrited and if they are machined they are very soft under that thin coating.
Hopefully I won't need to machine my crank, but I like to be prepared.
Posted on: 2009/10/4 16:38
vetteoz Re: Stock cast crank question
Some of the factory over the counter performance cranks are nitrited.I don't believe they are any "softer" underneath than a regular crank seeing as they are listed as same 1053 material.
The grinding concerns comes from removing the hardened surface which puts you back to a regular crank surface unless you get the journals re-nitried after grinding.
Posted on: 2009/10/5 6:23
Zagreb, Croatia
326 Posts
You're probably right. But i know that most of Alfa Romeo engines can't last unles journals are renitrited after machining.
Posted on: 2009/10/5 12:19
BillH Re: Stock cast crank question
Stock Formula Ford cranks(Cortina/Pinto) are ground ten under with no treatment.
Posted on: 2009/10/5 12:37
