209 user(s) are online (171 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
movnviolation Elevation sensor?
Hesperia, Calif
188 Posts
What on my 89 controls the running conditions at different elevations. My car is modded with Mini, heads, cam and headers etc.
My tuner is in the Los Angeles area and set the air/fuel ratio right on close to sea lavel. The car smokes (hauls ass) down there. I live at 3600 feet and the car runs good up here, but when it idles, it loads up and idles rough. Just changed the IAC, and the old one was covered with carbon. Looked like the inside of a chimmney.
no codes!
Any thoughts?
Thanks
Posted on: 2009/10/27 2:43
Mods
Aboatguy Re: Elevation sensor?
My Avatar was redistributed!
498 Posts
no codes!
Any thoughts?
Thanks
MAP sensor?
Posted on: 2009/10/27 2:45
movnviolation Re: Elevation sensor?
Hesperia, Calif
188 Posts
Thanks
Would a failed MAP sensor throw a code??
Posted on: 2009/10/27 2:57
Mods
bogus Re: Elevation sensor?
yes.
Posted on: 2009/10/27 3:00
Hesperia, Calif
188 Posts
Thanks
No codes!
Posted on: 2009/10/27 3:19
Mods
Hesperia, Calif
188 Posts
No MAP sensor on the 89. 84 and 90-95 used MAP. 85-89 used MAF.
Posted on: 2009/10/27 8:07
Mods
mseven Re: Elevation sensor?
Motor City Madhouse
247 Posts
It needs more tuning, the AFR maybe good at wot but normal c.l. operation sounds pig rich.
Posted on: 2009/10/27 9:20
