222 user(s) are online (174 user(s) are browsing Forums)
Also known as NHMS....
anesthes Joe Sherman 408 small blocks.
Boston, MA
This is a nice build:
350 block, bored .030 over
AFR 210 eliminator heads
Scat 4" stroke crankshaft
Scat 6" rods
Comp cams 270/280 (@ .050") camshaft, 109 lsa 106 ctr
.454/.438 lobe lift, 1.6 rockers) solid roller.
Victor intake
1095 CFM demon carb
1 3/4" headers
667 HP at 6,800 RPM and 564 tq at 5,200 RPM.
Now I wouldn't build something that spins this high, but this is a pretty damn good example of what a thought out small block could do. This is a engine he builds for customers, retail is $12,000 with spiffy rockers, timing set, cover, pan, valve covers, and all sorts of goodies.
Joe Sherman also builds another 408 for more street-oriented use which is more up my alley. AFR 195 heads rather than the 210s, a 750 CFM carb, smaller camshaft, and an edelbrock performer RPm manifold ( sounds like my combo) and 10.5:1 compression, which produces 568hp at 5,800 rpm and 568 foot lbs or torque.
Both combos run on 91 octane.
My combo uses a 400 small block as a basis, so with an over bore I have a hair more displacement at 412 cubic inches. I'm using a 750 cfm carb and the edelborkc performer rpm intake. Camshaft is XR288HR, because in the end I decided I didn't want to adjust my valves monthly. Heads will probably be AFR 195, as I think the 195s have better port velocity than the 210s so cruising sub 3,000 RPM would be better on the street. At 10.9:1 compression ratio, I'm shooting for mid 500s at the flywheel. Which is hopefully enough to propel a heavy 2nd gen Camaro into a decent e/t.
-- Joe
Posted on: 2009/11/10 14:38
mseven Re: Joe Sherman 408 small blocks.
Motor City Madhouse
247 Posts
sounds like a regular sherman build, big power and cammed to the moon....lol
Posted on: 2009/11/10 15:02
383tpimachine Re: Joe Sherman 408 small blocks.
Corpus Christi
976 Posts
What are the flow numbers on the 210 elim vs the 195 elim?
Sounds like an engine I want
Posted on: 2009/11/10 15:23
1970 El Camino-Awaiting LSX
anesthes Re: Joe Sherman 408 small blocks.
Boston, MA
I'd leave that question to tony, but probably low 300s at .500+ lift.
-- Joe
Posted on: 2009/11/10 16:24
Boston, MA
True. Still impressive power for the size of the motor.
-- Joe
Posted on: 2009/11/10 16:25
Motor City Madhouse
247 Posts
-- Joe
no doubt, he has always made impressive numbers with a sbc.
Aside from the really big inch stuff of Sonny Leonard, I have always been partial to the Reher Morrison builds. In recent times, it appears their prices have also become more reasonble.
Posted on: 2009/11/10 16:51
Boston, MA
mseven wrote:
-- Joe
What is your feelings on Daron Morgan? Apparently he worked for Reher Morrison for a number of years, and now does heads for Pro-filer.
-- Joe
Posted on: 2009/11/10 18:57
Motor City Madhouse
247 Posts
I've read quite a few tech articles by him and I believe he posts over in speedtalk. IMO, one of the best and and informative out there. I have a local guy who's "pretty good" too..Carl Foltz (CFE), and another one who is on that very short list. All of those guys are over my head in knowledge base and in what I would ever consider/afford to build.
Posted on: 2009/11/10 19:58
