131 user(s) are online (73 user(s) are browsing Forums)
Very stout.
spro2395 Z06 Seats
11 Posts
Does anyone know if 03-04 Z06 seats will fit in my 85?
Thanks
Posted on: 2009/11/30 17:30
Durango_Boy Re: Z06 Seats
I can't speak for C4s specifically but I might be able to add a bit of input that might help make the decision.
I have a 1977 C3. A C4 seat swap is a very common upgrade for C3 owners. The tracks are a bit different but the seats 'fit in the car. So, changing the tracks on the C4 seats to C3 tracks is really all it takes to swap seat.
Likewise, a C5 seat swap into a C3 is very popular. Again I think the hardest part of the swap is the seat tracks.
Using this as logic, that C5 and C4 seats can be put in C3s, I would 'assume' that barring a little seat track fabrication, it wouldn't be too hard to get C5 seats in a C4.
Posted on: 2009/11/30 19:33
BrianCunningham Re: Z06 Seats
The base C5 seats have a hole in them which can be used for a harness, which is cool, the Z06 seats do not.
Photobucket
Posted on: 2009/11/30 20:37
1Fast04Vert Re: Z06 Seats
According to the exspurts on CF the C5 seats are 2" too wide to fit in a C4.
Posted on: 2009/11/30 21:30
that really needs a comment, but I'll refrain.
Posted on: 2009/11/30 21:46
bogus Re: Z06 Seats
weather that is true or not is irrelevant to me.
What is relevant is this: the Z06 seat SUCKS.
Posted on: 2009/12/1 5:37
Danspeed1 Re: Z06 Seats
Mooresville, North Carolina
1121 Posts
[IMG]http://i142.photobucket.com/albums/r97/BG528/100_1721.jpg[/IMG]
Not that it matters, but C5 Seats fit very well into C3's.
You should look into the C6 seats. I don't know if they are any bigger or smaller, but they feel a heck of a lot tighter than c5 seats so... it might be worth a gander.
I could measure mine if you would like.
DG
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
VetteMed Re: Z06 Seats
Alachua, FL
37 Posts
Actually, the ZO6 seats are just base seats with embroidery. The Sport Seats are the ones with the slot for the harness. Either way, C4 seats are way better in comfort and grip.
Posted on: 2009/12/2 0:42
