178 user(s) are online (112 user(s) are browsing Forums)
movnviolation Distributor knocks the s%^$ out of me!
Hesperia, Calif
188 Posts
I am back to chasing a miss on my 89. Going after the ground wires now. Everything is new except wiring.
But should the dist knock the socks off of ya when adjusting the timing? Don't remember the old one doing that. I realize they are high energy!
Posted on: 2010/1/11 4:58
Mods
bogus Re: Distributor knocks the s%^$ out of me!
uh, no.
If the cap is frying you, check that cap for a crack, or, a bad boot or connector for the wires.
I am a HUGE fan of Taylors.
Posted on: 2010/1/11 5:00
movnviolation Re: Distributor knocks the s%^$ out of me!
Hesperia, Calif
188 Posts
Have new MSD wires and dist is new. Have had mechanics say yes and no. Hate to replace things to see if it solves anything! That gets expensive!!!
Posted on: 2010/1/11 5:24
Mods
It doesn't mean something isn't amiss.
You can figure out which is causing it. IT might be a small tear or a crack in the cap. The cap could have been made with a problem.
Posted on: 2010/1/11 6:08
Woodstock Re: Distributor knocks the s%^$ out of me!
Bremen/Germany
369 Posts
The knock sensor can do strange things. Make sure you got the right sensor to start with.
I had a friend here with a pulsating idle. He changed the sensor twice and it still was the sensor. It would only show up when reaching a certain temperature.
With the diagnostic software you could see the sensor coming in always late, when the knock should be over under normal circumstances.
Posted on: 2010/1/11 15:52
91 convertible
Matatk Re: Distributor knocks the s%^$ out of me!
Cap shouldn't fry you when adjusting it. Do what Andy suggested, check for cracks, arcs, loose or broken wires.
Posted on: 2010/1/11 19:40
klkordzi Re: Distributor knocks the s%^$ out of me!
Pittsburgh, Penna
152 Posts
Try running the engine with the garage lights off and see if the are any obvious arcs coming off the cap
Posted on: 2010/1/12 0:05
Hesperia, Calif
188 Posts
Tried the lights off at night, nothing obvious visually, gonna have to replace things (again) I guess.
Thanks
Posted on: 2010/1/12 3:06
Mods
