137 user(s) are online (86 user(s) are browsing Forums)
BrianCunningham Bear 0 Housecat 1.
Posted on: 2010/1/25 21:06
CentralCoaster Re: Bear 0 Housecat 1.
Damn, disappointing.
I guess it's not such a bad thing after all to taste worse than garbage.
Posted on: 2010/1/25 21:30
bogus Re: Bear 0 Housecat 1.
gee... plucky little kitty, tho...
Posted on: 2010/1/26 3:49
Curtis1974 Re: Bear 0 Housecat 1.
Bolingbrook, IL
1070 Posts
You would think the cat would have been a better snack!
Posted on: 2010/1/26 14:34
Purchase date: 11/23/2003
