240 user(s) are online (126 user(s) are browsing Forums)
Durango_Boy Bell Housing Compatability.
Does anyone know, regarding the Chevy Borg Warner T5, would a bell housing from a '99 Camaro 6 Spd fit the bolt pattern of the T5?
I picked up a cheap T5 from a V6, so obviously the bell housing won't work. Same year, '99, there was no 5 Spd option for the 350...just the 6 Spd.
If the 6 Spd bell housing will bolt up to the T5 then I can get one cheap and solve the compatibility issue.
Posted on: 2010/4/8 1:50
Curtis1974 Re: Bell Housing Compatability.
Bolingbrook, IL
1070 Posts
I'll ask Jon about this when I pick up the C3 tomorrow. He might know.
Posted on: 2010/4/8 2:38
Purchase date: 11/23/2003
pr0zac Re: Bell Housing Compatability.
no.. its totally different
Posted on: 2010/4/8 12:52
http://www.summitracing.com/parts/LAK-15020/ if you can't find a used one.
Posted on: 2010/4/8 12:55
Bolingbrook, IL
1070 Posts
Wow! They're pretty proud of those bad boys..........
Posted on: 2010/4/8 13:22
Durango_Boy Re: Bell Housing Compatability.
I will look for a used one, but what year and model do I search for? I tried looking at Camaros but the only V8 I saw the 5 Spd available with was a 5.0 L.
Will a bell housing from a 1992 Camaro 5.0L engine fit the T5 from a '99? I can find those easily.
Posted on: 2010/4/9 0:47
not sure if the input shaft is the same for the 99 t5. i would imagine it is because i know you could use a older v6 trans on a v8 if you swapped the housing but the trans wasn't as strong. no 350's were 5 speeds in third gens.. just the 305's tpi or tbi and v6's.
Posted on: 2010/4/9 4:36
