231 user(s) are online (168 user(s) are browsing Forums)
jmartynuska RR Tire Hop/Rapid wear
Rindge, NH
51 Posts
I've been chasing a bad vibration/tire hop in the rear. Put tires on it mid-January. Fronts look brand new, rears are smooth.
Think this could be the cause, or most of it?
RR Lower Dogbone mounting hole
Posted on: 2010/4/13 19:43
Andrew Re: RR Tire Hop/Rapid wear
Jefferson City, MO
447 Posts
Could it be because of:
http://www.youtube.com/watch?v=FAx7lDNmcmQ
Seriously, I've never seen what you posted. How bad is the vibration? I would think if it was the dogbone mounting hole, it would shake like crazy.
Posted on: 2010/4/13 20:41
2003 Atomic Orange Z06
SOLD 1979 4 Speed with 383
BillH Re: RR Tire Hop/Rapid wear
Need more info. Vibration and tire hop are really 2 different things.
Vib - when, what speed, under acceleration, deceletation?
Tire hop, again when? Hard launch, around corners?
The only thing in your vid that I can think of that would cause that is a bolt that wasn't tightened properly. It had to be working on the holes for a while to do that.
Posted on: 2010/4/13 21:03
jmartynuska Re: RR Tire Hop/Rapid wear
Rindge, NH
51 Posts
Real bad.....
Top hole is similar. The sleeve in the bushing the bolt passes through has a similar elongation, more so on the bottom bushing than the top.
Posted on: 2010/4/13 21:08
Rindge, NH
51 Posts
Vibration increases with road speed. What I think the "vibration" is - maybe my description isn't very good and may be misleading - is the tire either shaking back and forth or hopping up and down like a basketball.
Posted on: 2010/4/13 21:12
BrianCunningham Re: RR Tire Hop/Rapid wear
chicken vs egg, which came 1st?
fortunately those brackets unbolt, good time to upgrade to DRM brackets if you want to.
how the rest of it look, u-joints etc?
Posted on: 2010/4/13 21:17
jhammons01 Re: RR Tire Hop/Rapid wear
If you can see it hopping like a basketball, how old are the shocks?
Posted on: 2010/4/13 21:23
Rindge, NH
51 Posts
When I got the car, this is what happened to the RR outer u-joint...
RR Outer U-joint
I suspect that's when a lot of the problems began.
Rindge, NH
51 Posts
I can't see the tire hopping - I'll try to get someone to follow me or drive beside me and look at it. I sure does feel like the tire is moving a lot. The wear pattern was feathered across the center tread blocks.
U-joints are new, within the past year, both outer tie rod ends with in the last two months.
Shocks passes a basic push test and show no signs of leakage. I know, not real accurate or scientific, but the shock doesn't feel especially worn. I'd think if the shock was bad enough to be the sole cause, it would be noticeable with a basic push test. Rebound adjuster - Koni single - still functions in that I can see a change in extension when I fiddle with the knob.
Posted on: 2010/4/13 21:30
Have you checked the rear wheel bearing for play, should be done with the caliper off and a dial indicator but, if there's any movement in and out it ay be bad.
Have you checked the wheels for runout, lateral & radial?
This can be done with a pointer C clamped to a jackstand, check at the edge of the rim and on the bead edge (for up & down).
Or, if the car's drivable, switch tires side to side.
Bad shocks will amplify the problem but probably not cause it.
Posted on: 2010/4/13 21:39
Rindge, NH
51 Posts
Sorry, rear hubs are two weeks old. This is the second wheel/tire combo this has happened to. These tires were mounted up on these wheels when I changed the tie rod ends. I was hoping the new tie rods ends had cured the problem.
I do notice a difference with the tie rods and hubs.
I think just about every part in the rear is going to be replaced before all is said and done. Each part replaced makes a difference - new tie rods, car stopped wandering on accel/decel, new hubs, roughness and noise went away. I know it needs a new pinion yoke - I have one sitting in the garage from Randy's R&P.
Sorry if I'm omitting a lot of details - been frustrated for a while with this. Thanks for the help and suggestions thus far...much appreciated.....
Posted on: 2010/4/13 22:04
