230 user(s) are online (141 user(s) are browsing Forums)
Assembly Line Diagnostic Link
« 1 (2)
BillH Re: Coolant systems (clean and properly maintained)
From the last flush, not too shabby.
2 gallons of Prestone and water for $1.99? I gotta start shopping where you do
jpg  IMGP0711.jpg (0.00 KB)
Posted on: 2010/4/4 16:51
jhammons01 Re: Coolant systems (clean and properly maintained)
^^That is good for a ~20 year old car.........
Posted on: 2010/4/4 17:26
The flush before that went in was the first I did on the car. The stuff that came out had quite a bit more crap. That flush has the knock sensors pulled (amazing amount of crap left in the block that draining didn't remove). I took a hose and sprayed in the sensor holes, more crap came out. Then filled with straight water, burped, warmed to 195 and reflushed.
The payoff shows in the pic.
I just pulled the coolant (6 months old) out to put gashets in the w/p. It looked like new.
Posted on: 2010/4/4 17:50
CentralCoaster Re: Coolant systems (clean and properly maintained)
jhammons01 wrote:
LOL......Poor it down the sink or toilet. That way it goes to the sewage treatment plant prior to directly to the ocean.
Kinda hard to capture and carry 40 gallons of water into the house.... that it typically takes me to flush the system. The coolant's out, this is mostly rusty water with a trace of Prestone.
Posted on: 2010/4/4 21:19
Z51L9889 Re: Coolant systems (clean and properly maintained)
Dayton, OH
18 Posts
The capturing is no problem, Snag a $10 kiddy pool at China-Mart and slide it under the car -- problem solved.
I totally agree with the carrying into the house issue.
Posted on: 2010/5/10 19:24
« 1 (2)
