132 user(s) are online (98 user(s) are browsing Forums)
GRIS, more...
corvetteronw Flip flapping door panel easy breezy fix
Lowell, MI
I cannot take credit for this as I saw it somewhere else.
Just checked this off my list of things to fix on the 91. This was much easier than getting the hardware right on the headlight gear fix of last week.
10 minutes tops.
Tools needed: 10mm socket, ratchet drive and extension, thin nose vise grips.
purchase a pack of brass (so they won't rust in the future) 1" X 1/2" corner brackets.
Locate the most rearward window felt, clamp the felt with the vise grips and remove the 10mm bolt from the felt bracket. Reinstall the bolt and your corner bracket:
Here it is installed:
Lift the inner door panel up over the bracket:
It's done: Make sure the window still goes up and down ok.
On the driver's side I had to bend the bracket upward a bit as the door panel popped off when I closed the door.
Pour yourself an icy cold one!
Posted on: 2010/6/21 17:49
Matatk Re: Flip flapping door panel easy breezy fix
Nice pics, Ron.
Posted on: 2010/6/21 20:33
corvetteronw Re: Flip flapping door panel easy breezy fix
Lowell, MI
Matatk wrote:
Nice pics, Ron.
I will do the same thing when I install your ported intake manifold along with my Bosch IIIs and SLP runners.
See you this weekend.
Posted on: 2010/6/22 2:32
biggrizzly Re: Flip flapping door panel easy breezy fix
I did this fix several years ago and if you use your car frequently the L brackets will do two things... they will begin to bend and allow the panel to slip off again and they will also chafe the panel and allow it to slip off. It will indeed work for a while, but in my opinion this is not a permanent fix.
Posted on: 2010/6/22 12:25
Steve40th Re: Flip flapping door panel easy breezy fix
1114 Posts
Maybe a better metal bracket would help. They do bend easily.
Titanium sounds good ;)
Compared to the price of a new panel, I will replace mine when they bend, as mine have been in for a couple years/
Posted on: 2010/6/22 14:50
Ko'u ohana aia ku'a ikaika
bigmoe Re: Flip flapping door panel easy breezy fix
Manitoba
118 Posts
The brackets I used were fairly sturdy. I filed the top smooth and put a few pieces of duct tape on the top so it wouldn't cut into the panel. Best fix for this problem I've seen so far though.
Posted on: 2010/6/26 19:17
