176 user(s) are online (142 user(s) are browsing Forums)
vis_croceus (LT1) EGR pipe fitting size?
VA
260 Posts
Need to get a tap and clean up EGR/Air threads on header.
Measured at 7/8-18, but then I search and find that the Camaro LT1 EGR/air fittings are metric, so now I'm doubting my measurement...
Anybody know for sure what it is?
Posted on: 2010/7/14 21:35
94 vert
vetteoz Re: (LT1) EGR pipe fitting size?
IIRC 22mm x 1.5
Apparently some later cars had 18 x 1.5 ;same thread as O2 sensor
Posted on: 2010/7/14 21:45
vis_croceus Re: (LT1) EGR pipe fitting size?
VA
260 Posts
Thanks.
That corresponds with what I found on the F-body forums - M22 for OBD1 and M18 for OBD2.
Posted on: 2010/7/14 22:28
94 vert
VA
260 Posts
I rechecked the thread and it's definitely a -18 not a -1.5
How do you measure diameter on this sort of fitting? Not sure if it's a bolt (OD) or pipe (ID) thread...
Posted on: 2010/7/15 9:39
94 vert
BillH Re: (LT1) EGR pipe fitting size?
Steve,Can you get a mike on the tube nut threads?
An 18 will measure around .670 inch on the major diameter (thread peaks) for a 1.5 thd. and .644 for a 2.5 thd.
that's roughly off a chart I saw.
Metric threads are slightly smaller than the size indicated, an 18 is 16.4 to 17.1 mm on the diameter.
Did you use a thred gage to determine that it's not 1.5?
I've onll had a couple out and never checked the threads but they sure felt like a pipe thread when I put them back together (I could be wrong though).
Posted on: 2010/7/15 13:54
VA
260 Posts
~0.865" = ~22.0mm major diam.
Did you use a thread gage to determine that it's not 1.5?
Yep.
And then I drove all over town until I found a place with a 7/8-18 nut to check it with...
Also after more googling found out that a lot of US cars EGR are 7/8-18. I think the F-body guys are just forcing an M22-1.5 on there. M22-1.5 and 7/8-18 are close enough that you'd probably just think it was stubborn...
Posted on: 2010/7/15 18:11
94 vert
Yea, there some other metric sizes that will accept a US nut,etc.
Good Luck
Posted on: 2010/7/15 21:06
VA
260 Posts
Acquired a 7/8-18 oil drain plug and confirmed fitment.
For those needing a block off plug for EGR/AIR:
NAPA BK7041016
Now I just have to buy a $40 tap to fix my $150 headers. Resized Image
Posted on: 2010/7/15 22:40
94 vert
