Weavsvet | Should I change these springs? | ||
Right now I have AFR 8019 springs on my 195 AFR non competition heads. I have the 8117 springs sitting here but I'm still wondering if it's even worth while to do. Steve40th said he had this issue a while back and changing springs to a lower rate helped with overall feel on the engine. But that was his engine and I'm sure mine is different than his was. I'm not doubting Steve I would just like to hear some other opinions on whether it is even worth while to do.
I'm still having split blms of 20% on average higher on bank 2 than bank 1. I've checked everything I can find to check and cannot seem to help them any. Could these springs be contributing to this spilt blm issue? Cam 226/230.565.565 111 lsa AFR 195 street eliminators(non comp),58cc chamber, .026 head gasket Stock bottom end A4 w/2800 stall 3.45 dana 44 weight 3400 lbs with me in it Here are the spring specs: AFR-8019 1.270 OD seat pressure 155# @1.810 Premium Grade coil bind 1.080 Rate 428 Max recommended lift .650 AFR-8017 1.290 OD Seat Pressure 135# @ 1.800 Premium Grade coil bind 1.050 rate 360 Max recommended lift .600 |
Posted on: 2010/8/7 13:48
1996 Corvette Coupe,AFR 195 street Eliminators,Edelbrock LT4 Air Gap intake manifold,9.5" 2800 stall,TPIS LT headers,Bullet 226/230.565.565/111 lsa cam,1.7 Scorpion rr's,EWP, X Pipe, Stock Exhaust,Elec.Cutouts,Dana 44/3.45, Tune by Wester's Garage |
Stl94LT1 | Re: Should I change these springs? | ||
I'm running a similar spring to your current, without any ill effects. Before these I was running 918 beehives and they didn't work well with my camshaft (224/230 605/622).
I don't see how your current springs could effect your blms? |
Posted on: 2010/8/7 17:46
Steve40th | Re: Should I change these springs? | ||
I thought Beehives were only good to 600? Please correct me if I am wrong. I know nitrided beehive are better, .. |
Posted on: 2010/8/7 17:51
Ko'u ohana aia ku'a ikaika |
Steve, the beehives I was running was an early version that was rated at .625 max lift.
Posted on: 2010/8/7 18:28
Weavsvet | Re: Should I change these springs? | ||
One thing that bothers me about these big ass springs is my lifter preload doesn't seem to want to hold. I set it at 1/2 turn a couple of times now and after I run the car a while those rockers are sounding like a sewing machine just clicking away. Maybe that is normal I don't really know. There's a couple of them that are noticeably louder than the rest.
Posted on: 2010/8/7 18:40
You had the good ones like me, very early before they were made in a foreign country, at least COMP Cams. I will buy from PAC racing if I need new ones. |
Posted on: 2010/8/7 20:17
Yep! |
Posted on: 2010/8/7 21:04
383tpimachine | Re: Should I change these springs? | ||
Could it be to stiff a spring for the lower lift cam?
Posted on: 2010/8/7 21:33
pr0zac | Re: Should I change these springs? | ||
not true. depends on the ramp of the lobe, harmonics, pushrod diameter, valve weight.. |
Posted on: 2010/8/8 6:27
I've decided to leave them be for now.
Posted on: 2010/8/9 17:57
