234 user(s) are online (189 user(s) are browsing Forums)
NeurOn TH 700 problems
Kanal/Slovenia/Europe
11 Posts
Hi guys...i have one or more big problems with my renewed TH700 1991 vette transmission..
trans guy did the work and we putted in also TCI constant preshure valve body...at first trans worked ok..with hursh engagment when i switched to drive or other gears..then after 60 mils of driving it died..but was not like before that burned only 3-4 gear..now there is no gears at all!!today i will take my car in the garage and tried to find what is wrong..
in the manual ATSG sais that is something wrong with my converter if i don't get any gears...
have any ideas?
thanx!
BR,Seba
Posted on: 2010/8/21 13:40
zoe6 Re: TH 700 problems
Northern Indiana
167 Posts
Check the ATF fluid color, hope its still bright red! Maybe Trans guy lift out a check ball or spring, converter should lockup at 45 mph. Just a thought.
Posted on: 2010/8/21 13:45
Owner of a great Vette! Totally stock ZO6
PeteK Re: TH 700 problems
More info is needed before any guess can be made.
Fluid full?
Fluid burnt?
Shifter linkage working properly?
Filter cracked, broken, or leaking anywhere including the o-ring?
Converter bolts verified to be installed, and tight?
Forget about the ATSG for the moment. It is very useful on a stock trans. Once major mods are done to the hydraulic's, all bets are off. If you are lucky, you broke the pump, or a the forward apply piston (assuming reverse still works).
Posted on: 2010/8/21 15:51
NeurOn Re: TH 700 problems
11 Posts
thanx Zoe;)...yeah i will check what the hell he did to my trans;)...
BR,Seba
Posted on: 2010/8/23 5:42
11 Posts
hi Pete....
*the fluid was full...i dismounted the trans from the vette now and i will open it in next weeks..i have to make some tools first...
*fluid smels a little bit, but is not brown..is normal red..like new condition...
*shifter linkage worked properly since i drove with the car 60 mils and everything worked perfect...only problem i noticed was harsh engagemant..it was very severe...but then it worked great...
*everything was new..filter oil....there was no leakage...
*converter bolts were on
i also first assumed that the pump is gone...i will see..i will keep you informed...
i will check also forward apply piston...there is also no reverse;/...
there is no gear at all...when i put in any position there is no effect..
Pete it happend between i drove..there was no noise or bump before this...it was in Drive position...i drove normaly 40 mils/h after some cars infront of me...and then when i tried to accelerate...it was like in neutral...
it was not like last time when my 3-4 burnt out...but 1-2 stil worked properly...and the oil was also brown...i hope i dind't burn the clutches..
i have Raybestos blue plate clutches in...
Thanx for now..
BR,Seba
the trans is in my garage now...so i will disasamble it in a while,,,
Fluid full?
Fluid burnt?
Matatk Re: TH 700 problems
22808 Posts
Did you get to take this apart yet? I'm interested to hear the results.
Posted on: 2010/8/31 2:16
